Possible Air Tank?
John C. (ca)
07-15-2003 01:41:49
Hello Group:
Looking at picking up this tank. Has no ASME Label on it. But, has been used for a Air tank.
Any thoughts? Looks like it was a tank for a Halon fire system. Thanks for any opions.
John C. (ca)
dave
07-16-2003 12:32:32
 Re: Possible Air Tank? in reply to John C. (ca), 07-15-2003 01:41:49
HEY DONT WORRY about it, pumpo it full of air, from your compresser, if it's still in one piece bypass that little safty switch on your compresser and pump it up to a couple hundred pounds, just stand WAY WAY back when you do this AND try to set the tank near something you dont want in one piece anymore( iwould suggest a beaver dam that shouldnt be where it is(if you dont have one you canm borrow mine)..... ..... ..... ..... ..... ..... ..... ..HEY seriously I'm kidding never use a pressure vessel thats not safe its way way bad(unless you have beavers on your land)
RobertTX
07-15-2003 08:47:02
It does not look like it was built to ASME code. I say this because it does not seem to have the correct ends on it. If you cannot find a tag, I would not recommend it for air storage at any significant pressure. What happens with non code tanks is that they can fatigue and let loose unexpectedly. The results can be fatal. Please be careful.
John C. (ca)
07-15-2003 09:19:37
 Re: Re: Possible Air Tank? in reply to RobertTX, 07-15-2003 08:47:02
Hello
The more I think about it the more I am becoming aware that this is not a good idea.
Thanks
John
kjm
07-16-2003 21:15:56
 Re: Re: Re: Possible Air Tank? in reply to John C. (ca), 07-15-2003 09:19:37
John, I am using an old 100# LP bottle and it works fine.(I did have to drill out the restricter in the valve)
mj
07-23-2003 14:40:29
 Re: Re: Re: Re: Possible Air Tank? in reply to kjm, 07-16-2003 21:15:56
Ditto on the 100# propane bottle.
