Any ideas how to put an hour meter on an......
chris smith
07-13-2003 19:51:21
air compressor?? I have an emglo portable compressor and a campbell hausfeld belt drive that would be nice to keep up with the hours they run.. Any ideas?? Oh yea, i would like to stay cheap..
Thanks guys!!
fzbcheve
07-18-2003 19:16:06
 Re: any ideas how to put an hour meter on an...... in reply to chris smith, 07-13-2003 19:51:21
We are using a wall clock that has the old style sycro motor, wired to the motor of the compressor. Compressor runs, clock runs, Just set both hands straight up. Works fine.
Hanover Tom
07-14-2003 18:07:59
For gas engines the easiest is to buy a Briggs & Stratton "TinyTach"--When its off, shows hours, while running shows RPM. Simply groung one lug and wrap a wire pigtail around the spark plug lead. There is a cheaper version that only shows hours
wdTom
07-15-2003 17:25:46
 Re: Re: any ideas how to put an hour meter on an.. in reply to Hanover Tom, 07-14-2003 18:07:59
Do you know how much a Tiny tach costs?
Richard Fazio
07-14-2003 12:01:47
Cramer & COnrac sell hour meters that run on 120 volts. Just wire up to the compressor motor feed if it's 120 volt. If it's 240 bring one wire from the compressor feed and a neutral to the clock. I just stuck one on my generator.
wdTom
07-14-2003 18:05:16
 Re: Re: any ideas how to put an hour meter on an.. in reply to Richard Fazio, 07-14-2003 12:01:47
McMaster Carr has 110 and 220 volt hour meters. Also some that sense the vibration of the machine running to start counting too I think.
Slowpoke
07-13-2003 23:23:10
Northern Tool, for 2 & 4 cycle engines. Internal battery. $37 + s&h.
cdhris smith
07-14-2003 04:19:38
 Re: Re: any ideas how to put an hour meter on an.. in reply to Slowpoke, 07-13-2003 23:23:10
Yea but these got electric motors, don't know if it would work or not.. Whatcha think?
Chris
Slowpoke
07-14-2003 18:54:22
 Re: Re: Re: any ideas how to put an hour meter on in reply to cdhris smith, 07-14-2003 04:19:38
Sorry, I was thinking of gas engines for these 2 & 4 cycle meters. Look around flea markets and such. I found an almost new 120v meter for $3. Will put it on my 120/240v generator, with 11hp gas engine. It should work by wiring it across the back of the 120v receptical.
Used to be, one could by "war surplus" clock style hour meters. They work on 6-24v. Sometimes you will find them on old construction equipment.
David - OR
07-14-2003 06:36:46
Northern Tool has hour meters that run off 10 to 80 VDC for $24.99. Wire a socket up to your compressor's motor contacts, plug a 12V "cube" adapter into that (you probably have several around the house), and wire the hour meter up to the adapter. McMaster Carr sells an AC-powered hour meter for $27.00. Wire it in parallel to the motor and skip the adapter bit. You can point and click your way to one of these at www.mcmaster.com. You can probably buy the same thing for less at the local "wholesale only" HVAC or industrial supply store if you have an account or know someone that does.
Too spendy to suit you? Scrounge for an old-fashioned ac powered but mechanically operated desk clock/calendar at a garage sale. You remember -- the kind with the internal drum that "flips" from one day/month to the next. Set the clock to January 1, wire it up to the motor. You'll have to do some mental gymnastics to convert month/day/time back to elapsed hours.
