Advice on buying a TIG welder
Mike
07-12-2003 18:09:30
Hello,
I am looking at buying a TIG welder for home hobby use. I am looking at the Lincoln Square Wave TIG 175 Pro and the Miller 180. Does anone have experience with either of these machines? Should I buy a machine with the hand amp control or is the pedal sufficient? Any advice would be appreciated.
Thanks,
Mike
BFO
07-14-2003 19:05:38
 Re: Advice on buying a TIG welder in reply to Mike, 07-12-2003 18:09:30
I have the Miller machine and like it a lot, but wish I had bought the 250 instead of the 180. There just isn't enough amperage to do aluminum in any grate quantity. Great for SS though
Jeff
07-12-2003 21:32:36
Both are good machines.
Hand and pedal each has its place.
Mostly I use pedal, occassionaly
the hand control.
Mike
07-12-2003 18:22:08
Mike
I have the Lincoln Square Wave 175 Pro and REALLY like it.I have also used an older 180sd and it is also a nice machine,Hmm I'm a lot of help.
I like the Red machines(I have 2)but try www.hobartwelders.com/mboard and search there I'll bet you'll find some good info and a lot of good opinions.
Hope this helps.
Mike.
