Chevy tranny
Zach in colorad
07-12-2003 17:37:49
anyone know what kind of fluid to put in a 93 1/2 ton chevy with a manual 5 spd. Thanks, Zach
Fred OH
07-16-2003 07:53:05
 Re: chevy tranny in reply to Zach in colorado, 07-12-2003 17:37:49
Had the same problem with a 92 half ton 4wd and asked the service window at the local chevy dealer...he told me to look in the manual too...but had a buddy that is a chevy trained mechanic and he said to go to the parts house and ask if they had a replacement for it...they did...and it was made by Pennzoil (I trust them)...and it was quite a bit cheaper than from GM. It works...and it makes you feel better when you can beat the system. L8R....Fred OH
Revredneck
07-14-2003 06:28:42
Zach,
Your best bet is to look at your owner's manual for that info. There was more than one manual tranny that Chevy used then, and they all used different lube. Most of them used a synthetic oil that was pretty pricey, but you need to be sure before you put anything into it. If you have any questions about it, you probably should check with your local Chevy dealer's service dept. Good Luck and God Bless,
Tommy
