Drilling holes in old rail road wood ties.
Dave F.
07-07-2003 20:35:55
What would be a good way, & what type of bit to use in drilling wood rail road ties, I need to drill them & drive in 1/2" rebar to anchor them good to the ground so they don't move. Thanks Dave F.
Foz
07-10-2003 20:52:52
 Re: Drilling holes in old rail road wood ties. in reply to Dave F., 07-07-2003 20:35:55
Hi Dave, Let me save you a bunch of work here.cut your rebar square on the end, then beg-borrow or steal a roto-hammer. put the tie where you want it and drive the rebar right through the tie and into the ground! works every time for me!....Foz
Central Minnesota
07-10-2003 18:25:07
Bus Driver has the answer. A Ship auger has no flute to dull (or break off) on the first rock or piece of steel you hit. Can be sharpened with a file but seldom need it. Acutally they are pretty reasonable considering the number of holes you can drill before it's worn out.
C Kulig
07-08-2003 18:27:30
I was just outside drilling through them with a 3/8 spade bit.
also I was only useing a 3/8 drill, I had no problems at all
Kevin
07-08-2003 17:13:18
I predrilled with a 3/8" twist bit and finished with a spade bit. The predrilling gives the little tip on the spade something to follow for straightness. My 1/2" B&D walked right thru them. HTH.
RAR/IA
07-08-2003 15:14:13
I have used a special single fluted bit with a screw thread on the end. Requires a half inch drill, but works fine and can be sharpened with a file. Avoid any inbeded balast (railroad bed rocks and gravel). For what it is worth.
Hardware stores have them.
RAR
Mac
07-08-2003 06:39:59
I generally just used spade bits with an extension. Cheap and you can resharpen as needed. Need a pretty good drill, 3/8 anyhow.
Bus Driver
07-08-2003 04:24:19
Most of the manufacturers now call it a Ship Auger. It is officially a "ship head car bit". Sold in a few sizes at Lowes and HomeDepot. Most electrical supply houses have them. It does take a rather powerful motor to turn one of them. Does great in green, wet wood or in creosote treated wood
buck
07-07-2003 21:58:22
I usually use the paddle type bits because they are inexpensive and are easy to sharpen.
Steve from Tn
07-07-2003 20:44:30
Dave, I used a long twist type bit, not the paddle wood kind. The bit is expensive, I forgot how much. I had a heavy drill motor that I was lucky enough to borrow.
