What is a good rpm for cast iron compressor pumps?
chris smith
07-05-2003 09:02:07
I got to figureing how fast my campbell hausfeld pump was spinning. This is a cast iron, twin cylinder pump. The motor is a 15 amp 110 volt, 3450 rpm motor. The pully on the motor is 2.5" and the flywheel on the pump is 10". My calculations say it is turning under 900 rpms.. First are my calculations right?? Secondly, is this a good speed for a long lived pump?? I think i read somewhere if a pump is running under a 1000 rpms it is suppose to last longer.. So is my thginking right??
Thanks guys!!
Roger
07-05-2003 19:27:31
 Re: What is a good rpm for cast iron compressor pu in reply to chris smith, 07-05-2003 09:02:07
Your pump is turning 862 rpm, which is perfect.
