Weedeater
jetawn spivey
06-28-2003 17:15:41
I replaced the fuel lines on a Ryobi 31cc weedeater and the fuel lines leak at the gas tank. Is there a special method of replacement?
GG
06-28-2003 20:31:40
 Re: weedeater in reply to jetawn spivey, 06-28-2003 17:15:41
Most all gas tanks of this type have a fuel line that is slightly larger in diameter then the hole in the tank. This is what makes the seal. The trick to installing the new line is to cut the tubing on a 45 degree angle so that you can grab the point and pull it through. If you didn't have to do this, most likely the line is too small.
Jim Fairchild
09-02-2003 15:18:20
 Re: Re: weedeater in reply to GG, 06-28-2003 20:31:40
I have a new weedeater electric trimmer, I broke the line , can't find my instructions don't know how to get into the spool. Can anyone help
