`93 Ford clutch woes
John Humphrey M
06-25-2003 10:46:01
A friend has a `93 Ford diesel and can not get the clutch master cyl. and slave cyl. to live. The entire assembly has been replaced once and some of the parts have been changed again. Can not get system to bleed and truck is dead in the yard. Are there any "oh yes, this is what you do with that" stories.
Garry
06-28-2003 07:07:16
 Re: `93 Ford clutch woes in reply to John Humphrey Morocco IN., 06-25-2003 10:46:01
I haven't had experence with that paticular model but on another ford I put a whole kit in and all worked well. Then 50k later I had everything out for a pilot bearing repair and the pressure plate didn't look good and the clutch plate had some broken springs. I bought a new clutch and pressure plate from Ford but didn't change the slave throwout bearing combination because it was fine. The clutch wouldn't release and the final solution was to pull the transmission again and put a Ford slave in. The Ford slave was 228 dollars while the three piece kit I put in 50k earlier was only a 100.00 for everything.
Many of the after market parts are designed (or not designed) to be replaced as complete systems.
They don't really mimick the original parts on a piece by piece basis. The difference in lengths was obvious after the fact.
Also most clutches should more or less be gravity bled or if that doesn't work use a hand vacum pump. I have succeded in bleading them like brakes but it was not easy..
And if the slave throw-out bearing combo is to short you may be full of fluid and still not working..In other words a fit problem may make you think you aren't bleeding the system when you are..
Garry
Bob Knash
05-01-2005 18:06:28
 Re: Re: `93 Ford clutch woes in reply to Garry, 06-28-2003 07:07:16
Hello I have a 1992 ford ranger 4.0 4x4 5 spd. I cannot seem to get the slave cyl. to bleed.
It dosent matter what I do I have no pedel. I have replaced everything,master cyl.,slave cyl., and a new cluctch kit. have any pointers?
gatractorman
06-25-2003 14:45:11
I too have the same problem on a '94 F-250, I have owned the truck for 5 years and have put 5 or 6 slave cylinders on it never had the master to go out but I have changed it a couple times, my truck always has had a very stiff clutch pedal (good way to keep people from driving it lol) until today, I found a guy at my local Carquest auto parts that actually cared he done some calling and digging in books and came up with a replacement slave cylinder made from aluminum with quite a bit larger bore than the original plastic cylinder making the pedal much easier, I have been told to look for binding of the throwout bearing carrier causing too much pressure to have to be exerted by the slave cylinder mine wasn't but I remover the fork and greased the shaft as best I could from the outside also put a dab of grease on the fork pivot points after getting all the air out of the system today (the new aluminum cyl. actually has a bleed screw) my clutch works better than it ever has, I still have my receipt if you are interested I will get you the part number.
