Saw oiling question
Ludwig
06-21-2003 11:54:27
Okay, you fellers are going to laugh at me, but here goes.
How often to I have to use the oiler on my chainsaw? I've got an old Mac 110(I think, might be a Mac 10) that runs great and cuts real good. I've cut a few little spruce trees with it and I was giving it a pump or two every cut or two. Thats on 4-6" trees that it was buzzing through more or less like butter.
I noticed that after awhile I could actually see some oil in the sawdust that had accumulated on the saw, the sticky oil was holding the sawdust around. Does that mean I'm oiling too much? Does it matter other than I need to clean the gunk off occasionally?
Thanks as always.
Terry G
06-21-2003 21:50:42
 Re: Saw oiling question in reply to Ludwig, 06-21-2003 11:54:27
My Grandpa always told me it don't hurt one to run it without gas but don't run it without oil.
RWK in WI
06-21-2003 19:13:02
In an old Homelite manual I have for a manual oiling saw it states " Pump the manual oiler before starting each small cut. On larger cuts that take longer, pump the manual oiler every 10 seconds."
I hope this gives you some idea.
Bus Driver
06-21-2003 16:13:48
Use lots of oil. Not harmful (to the saw), very helpful.
Rod (NH)
06-21-2003 20:03:17
 Re: Re: Saw oiling question in reply to Bus Driver, 06-21-2003 16:13:48
I agree completely. Use plenty of oil. I used to go by the rule-of-thumb that you should be going through about a tank of oil every tank of gas for the old manual oilers. I am not sure where this came from. Perhaps it was something Dad told me years ago. Anyway, the automatic oiler on my relatively new Stihl 026P provides a continuous light throughoff of oil from the bar. You can see it easily when running the saw without cutting while over a snow background. It also goes through close to a tank of oil for every tank of gas automatically by itself. By such a "standard", if you only have to fill up the oil reservoir every three or four tanks of gas, you probably are not using enough oil :o).
third party image Rod
rhouston
06-23-2003 10:14:44
 Re: Re: Re: Saw oiling question in reply to Rod (NH), 06-21-2003 20:03:17
I don't cut alot but was told the same thing tank of oil per tank of gas on the old homelite manual oilers. My new saw gets about the same ratio
bob
06-21-2003 20:27:31
My Echo does the same, about a tank of oil for each tank of gas. Better too much than too little.
