Welding
tlak
06-14-2003 10:05:23
Is building a baler knife back up as simple as hitting it with a welder and grinding back down to shape or are we in to tempers, warping, specific rods? Not trying to build the whole blade just fill in a couple notches, probably rocks.
mj
06-15-2003 09:03:47
 Re: Welding in reply to tlak, 06-14-2003 10:05:23
Hit the dings with some 7018, re-shape the edge, say a few words over it and let 'er go.....:-)
Fred OH
06-17-2003 12:31:38
 Re: Re: Welding in reply to mj, 06-15-2003 09:03:47
mj...another rod would be 8018, 9018 or 11018 for cutting edges...11018 is so hard that you can't dent it with your chipping hammer after it cools a bit. I had a job once building up the blades on a hydraulic crane for a junkyard...it was used to pinch iron in two...thru axles and springs etc. It'll hold on a baler. Takes a DC welder to run it...preheat blade to around 400 fahrenheit...tempil-stik. L8R....Fred OH
