Block heater
sschock
09-06-1998 06:03:17
can anyone suggest a good cold weather block heater for my jd diesel. I live in Alberta and we see -25/ -35 often. I won't worry about colder that that. Thank you
chilly
09-06-1998 08:09:18
 Re: block heater in reply to sschock, 09-06-1998 06:03:17
: can anyone suggest a good cold weather block heater for my jd diesel. I live in Alberta and we see -25/ -35 often. I won't worry about colder that that. Thank you
Some body should sell KATTS block heaters up there. But i prefer frost plug heaters if they can be installed without too many problems in south dakota
Moe Aitel
09-23-1998 18:21:19
 Re: Re: block heater in reply to chilly, 09-06-1998 08:09:18
Some time ago, I installed a tank type block heater for a chap who took his vehicle to northern
Maine. It is a 1000 watt, sidearm tank that connects into the coolant loop and circulates the
heated coolant by convection. Manufactured by Phillips Mfg. Co. of Mineapolis, MN. It is easy to install and it worked fine at -20. You need
to be able to plug it in to a 120 VAC line.
While I was ordering, I stocked a second unit,
which was never installed, in original packing and with warranty card.
I will send it to you, UPS, prepaid on receipt of your $50.00 check.
