Exhaust System Leak Detection
Jimmy
06-12-2003 07:46:21
I am looking for a product that I can spray in the intake of a car to make the exhaust smoke so I can try to find any leaks.
Clint Proeschel
06-15-2003 19:00:52
 Re: Exhaust System Leak Detection in reply to Jimmy, 06-12-2003 07:46:21
If you don't want huge clouds of bad-smelling smoke, regular engine oil poured slowly into the carb will do the trick.
rustyfarmall
06-12-2003 13:17:16
Just trickle a little auto. trans, fluid into the intake, just a little and any leaks you may have will show up immediately.
Ben in KY
06-13-2003 04:35:49
 Re: Re: Exhaust System Leak Detection in reply to rustyfarmall, 06-12-2003 13:17:16
Yeah it sure will, The wife's Oldsmobile blew a diaphram out of the modulator valve. Which caused the engine to suck in ATF. Boy did that makes clouds of smoke :)
Ray
06-12-2003 09:38:18
Years ago I had a pickup with a stuck lifter. As recommended by others, I slowly poured a can of STP through the carb - smoked like crazy, but did free the lifter. Better have a wind blowing or you won't be able to see your exhaust leak for all the smoke.
