FS 74 Sthil Weed Whaker
PJW
06-10-2003 17:12:29
I have a Stihl Model FS 74, Serial Number 2274178 weed whacker that runs great up until today. The drive shaft broke off at the motor end. The shaft appears to be a spring construction with a square machined on each end. I would guess the working end has a gear with a female adapter to let the square end enter. The shaft slide out of the machine tube without any problem. Once I get the star socket head cap screws that hold the protective housing on it looks like I could weld or setscrew on a square adapter onto the broken end of the drive shaft. Has anyone tried to repair one of these shafts? I will check to see if a new shaft is readily available at a reasonable cost but the machine is at least ten years old and parts may be hard to come by. Also does anyone know where I can get wrenches for these blasted star socket cap screws?
PJW
[email protected]
David - OR
06-10-2003 18:07:04
 Re: FS 74 Sthil Weed Whaker in reply to PJW, 06-10-2003 17:12:29
Just about all weed whackers use the flexible driveshafts, even the straight shaft ones. They provide some shock absorption capacity if you are using a brush blade or heavy string. Plus the little two stroke engine isn't the smoothest to start with.
These driveshafts break all the time and you should be able to get a replacement part at the dealer. Cost will be $25.00 or so. Don't try to bugger a fix onto the old shaft -- it won't hold.
Home Depot sells Torx drivers that will fit the socket head cap screws. Or any good hardware store or auto parts place.
WRW
06-11-2003 11:57:50
 Re: Re: FS 74 Sthil Weed Whaker in reply to David - OR, 06-10-2003 18:07:04
While you are at the dealership buying a new driveshaft, ask them for a torx scrench. Or buy a T27 torx T-handle driver.
Did you get a tool kit with the trimmer when you bought it? There's usually a cheap driver in the tool pouch.
