Old craftsman radial arm saw
chris smith
06-09-2003 19:03:37
Are these pretty good saws? I have a chance to get an older model for 100$$ It is in good shape, cept needs a new table. So should i go for it?? Got any ideas on how to make a new table??
Thanks guys!!
rem
06-12-2003 12:57:47
 Re: old craftsman radial arm saw in reply to chris smith, 06-09-2003 19:03:37
Keep the 100 bucks and use it toward the purchase of a compound miter saw. MUCH SAFER!!!
I would not have a radial arm saw in my shop.
My 2 cents worth.
thurlow
06-12-2003 13:37:11
 Re: Re: old craftsman radial arm saw in reply to rem, 06-12-2003 12:57:47
Bought my Craftsman radial arm new at least 25 yrs ago; still works good; also have compound miter and table saw; they each have their "niche" and will do things the others either will not do or will not do well.....gotta come up with a band-saw.....
Farmered
06-10-2003 18:41:44
Made my table out of a piece of formica surfaced counter top. Ought to outlast Me.
Mac
06-10-2003 14:24:05
check recalls on these, if it applies you will get a kit which includes a new table
Tommy P CT
06-10-2003 17:42:41
 Re: Re: old craftsman radial arm saw in reply to Mac, 06-10-2003 14:24:05
I suggest you follow Macs advice before you get started. If you got the right Craftsman saw it will be worth it. Go to radialarmsawrecall.com and put in your Model #. If the model qualifies, they will send you a new table, blade cover and other hardware. FREE
Alot of guys lost their fingers over the years so they are giving the upgrade kit to help stop this.
chris smith
06-10-2003 04:05:51
Okay the model number is 113.19770. What i was wondering on the table was howe did you make your fence?? I have several ideas for the table, but no good ones for fence. If i could find the dimensions i would make a table like the original, where the frount is solid and the you have a back board, spacer, and fence all held with two clamps. Any ideas on the measurements??
Thanks guys!! Chris
Slowpoke
06-11-2003 00:03:31
 Re: Re: old craftsman radial arm saw in reply to chris smith, 06-10-2003 04:05:51
I have a 16 pg. assembly & operating instructions book for model 113.29410. I think it's late 60's to early 70's. No table dimentions are given, but it hangs over the edge of the side rails about 4".
A 2-3" wide piece of the same length lays across the back. Then an upright of about 2-1/2" high is sandwiched in between as a fence. You need leveling screws to get the table & radial arm parallel and some table clamps to hold it together. Try to get the original table and hardware with the saw. Use it as a pattern to make a new one. If you can't get a book on your saw, email me and I'll make you a deal on a copy of mine. I don't think there's much difference.
Vern-MI
06-10-2003 03:34:52
I have a Saw Smith 10" radial arm saw that is about 40 years old and replaced the top using two pieces of 3/4" plywood glued together with Franklin glue. I applied several coats of polyurethane to seal it and cut down on splinters. The new top is larger than the old one at 24" x 48" and it makes moving the stock and locating it much easier. I plan to put a sacrificial layer of pressboard on top and hold it in place with brads.
Slowpoke
06-10-2003 00:06:02
There's lots of those saws around. Usuall sell for $75-$150 on the west coast. What's the model #?
buck
06-09-2003 20:16:35
We have two of the 10" versions in the family. Probably 15 to 20 years old. They are accurate and hold adjustments but down on power for some projects. A piece of good quality chip board will make you a good table if we are talking about the same saw.
George
06-09-2003 22:27:42
 Re: Re: old craftsman radial arm saw in reply to buck, 06-09-2003 20:16:35
My saw is around 24 years old and is still good for a few more years. I agree with Buck that the saw is underpowered, especially when ripping. (Tends to pop the thermal breaker and takes around 15-20 minutes to reset.) Blades gotta be sharp. Would recommend using 3/4 marine plywood for the table. Completely alinging the blade to the table is quite involved, but it might be that way on all RA saws.
