Original chain type Come Along source?
Rauville
06-09-2003 05:28:27
Is there still a source for the original single chain, non-spool Come Along? I have one that I use that is marked: "COME ALONG, J.E. SCHAFFER CO., TULSA OKLA.", and would like to find another. It's the simplest heavy duty tool I've ever seen. Thanks for your help.
Farmered
06-10-2003 18:53:50
 Re: Original chain type Come Along source? in reply to Rauville, 06-09-2003 05:28:27
Are you talking about a "differential chain hoist"? These are great for lifting. Ain't worth a hoot for horizontal applications. Try also: Northern Tool. Ed
KX
06-10-2003 09:15:11
Everything SCHAFFER made was heavy heavy duty. I have a JE SCHAFFER chisel plow that stands up to black dirt regardless how much moisture is in the ground. I have ripped mesquite stumps up with it that I couldn't see. I didn't know they made come alongs, but I am sure they are good quality.
Adam P
06-09-2003 19:47:51
Try Harbor Freight (.com, or store)
they might have something...
VaTom
06-09-2003 06:30:34
Hi Rauville,
You mean these? I use two CM's, a 1 1/2 ton and a 3 ton. Great tools, if heavy to drag around.
Rauville
06-09-2003 06:57:29
 Re: Re: Original chain type Come Along source? in reply to VaTom, 06-09-2003 06:30:34
What I have does not have a rachet, but instead "pushes" and "locks" the chain one link at a time with each throw of the lever. You anchor directly to the chain that you are using to pull with, rather than to the body of the puller. You are really pulling from both ends of the chain, and dropping a loop of slack chain as you pull. Apparently these were made before the term "COME ALONG" became public domain. Thanks
ShepFL
06-09-2003 07:57:29
 Re: Re: Re: Original chain type Come Along source? in reply to Rauville, 06-09-2003 06:57:29
Seen one on ebay just like you described. Dern thing sold for $82.00. First one I have seen since late 70's.
FWIW
jake
06-10-2003 07:59:39
 Re: Re: Re: Re: Original chain type Come Along sou in reply to ShepFL, 06-09-2003 07:57:29
My Tool Store has them, bit pricy. Link below
