Tune Up Tools
RV
06-08-2003 20:03:42
An older guy told me they used to have Tune Up Tool Sets. They included everyting to change the points and condensor in a tractor. He said the one he had did not have anything for removing spark plugs.
He lost his 30 years ago, he said.
Are these still available? If so where?
If not, what do you suggest I put in my homemade kit?
I assume a small screw driver, open end wrench (5/32's if I remember right) and feller gauge. What else?
TIA
JDK
06-09-2003 21:18:12
 Re: Tune Up Tools in reply to RV, 06-08-2003 20:03:42
Motorcycle mfgs used to be great at this,Everthing you needed for routine maintenance in a tiny kit,Innovations were rampant with screwdriver tips on ends of pliers handles,single leaf feeler gauges riveted to flat sides of wrenches,nesting tube type sockets for plugs/axle bolts.Entire tool kits would fit in a beer can sized space.Shame they were metric :(...
Lessee,***Slip jt pliers(small),multi-bit screwdriver,2 short double open ends(3/8x7x16,1/2x9/16)single leaf gauges for points/plugs,tube type plug wrench***small ballistic nylon or leather pouch to hold stuff.
Mike
06-09-2003 19:22:43
Hey RV
Check Sears they have a neat little tool for starting slotted screws.It is spring loaded and has a tab in the middle to grip the slot of the screw with the spring tension.They are also made for Phillips screws and I have one in the tool box but I don't now where it came from.Hope this helps. Mike
rustyfarmall
06-09-2003 10:00:54
You will want something to hold onto those tiny little screws with, your fingers are too big. You can get a magnetized screwdriver that will do the job, but it will pick up everything else it gets close to also, I like the one that came with my Snap-on set, it has a little device which will lock into the slot in the screw, and hold it while you start it in the hole. I don't know if it is still available.
MPK
06-10-2003 17:21:40
 Re: Re: Tune Up Tools in reply to rustyfarmall, 06-09-2003 10:00:54
I have some very small open end wrenches which I don't use much anymore. What I use the most now is a very small channel lock type plier that is very handy. It seems to be the one I always grab first.
JDK
06-10-2003 19:03:48
 Re: Re: Re: Tune Up Tools in reply to MPK, 06-10-2003 17:21:40
Know whatcha mean,I've worn out a couple of them little 4" channel lock pliers.Need new pair.Gotta put em on my "wallet" Sears list(now)
