Hi, Dr Cy Kosis. I'm about in the same boat as you with regard to my metallurgy knowledge, except that I can also recognize a coppertop ore -- or a 'manganese' one. However, I have a metallurgist sitting here with me as I write this. He doubts that it is really magnesium plate. He suspects that it might be duralium which was/is used for lightweight requirements such as aircraft frames, radar towers, etc., etc.. To test, use a hand hacksaw to SLOWLY saw off a small corner, catching the saw filings as you cut. Then try to set that sample alight with a low setting on an oxy-acetylene torch on a sharp corner of the off-cut and also on the collected saw filings. Do this on a steel benchtop or a piece of steel plate. If it lights up and burns vigorously with a bright, white light and flying sparks, you've got a piece of magnesium. Everything else you do with that piece of plate from here on needs to be VERY cool. If it does not light up, it will most likely be duralium or some other aluminium alloy. If it does actually turn out to be magnesium, it could be drilled VERY SLOWLY UNDER RUNNING SOLUBLE OIL. This would then allow the insertion of a jigsaw to start cutting whatever shapes were wanted from the plate, AGAIN, UNDER RUNNING SOLUBLE OIL. LOTS OF IT. He recommends that you read the page at the link below re working with magnesium and dealing with magnesium fires. It does appear that heavy sheet or ingot magnesium is very hard to set fire to but magnesium dust, sawdust, filings or shavings can be set alight quite easily. Be careful. The best way though is to contact the manufacturer -- if known -- for details on dealing with this piece of plate --- if said plate is not already 'hot'. Hope this helps. You have a wonderful day. Best wishes. Deas Plant.
