Hi Tom, I ran thousands of feet of CU type ACR for refrigeration piping thats tested for 500psi with a typical working pressure of 350psi. About the same wholesale cost as type K (common hard CU pipe) and type L soft CU. Type M is a good choice for air line as it's slightly cheaper than type ACR but heavier wall than type K and rated for the psi. I clean the outside of the pipe with 80grit emery paper, the fitting inside with a fitting wire brush, then sweat the joint using Oxy/Acet with 15% silver solder. Pre-clean the solder rod with 80 grit emery. Harris brand on the 15% silver solder is the best. A flux is not required providing you keep the filler rod with in the gas envelope or close too the flame. This keeps the joint and filler rod from oxidizing making the solder flow easy. A purge gas of 5c/hr of AR, HE, Co2 or nitrogen works well to keep the inside joints from scaling while welding. Use a piece of masking tape for the end not being welded with a pencil lead size hole for purge gas to escape. They make a non-silver bearing filler rod called Harris Stay-Silv. Although it will do the job at 1/2 the cost ($24 vs $48/lb) of 15% silver solder, there is a big difference it the way the two solders flow into the joint. Pay the extra cost and get the 15%. T_Bone
