Zerk size
Gene
06-05-2003 19:23:36
I was about to put in a new Zerk fitting. It calls for 1/8" NPT. I have the tap , but do not know what size drill bit to use. I could not find the answer in any of my reference books. Could someone tell me the size or direct me to a website, please? Thanks. Gene
Gene
06-07-2003 06:46:45
 Re: Zerk size in reply to Gene, 06-05-2003 19:23:36
Thanks for all the replys. I used a 11/32 and it worked well. I think I will have to get a good machinists handbook. Gene
george md
06-06-2003 20:40:25
Gene,
1/8 pipe tap needs an ( R )drill (.339 )
george
rustyfarmall
06-06-2003 16:13:26
My machinists handbook gives two different sizes- eleven thirty seconds for a briggs pipe tap, and five sixteenths for whitworth, I'll venture a guess and say either one will probably work. The machinists handbook gets very technical, so sometimes you read between the lines.
Slowpoke
06-06-2003 22:27:36
 Re: Re: Zerk size in reply to rustyfarmall, 06-06-2003 16:13:26
I believe Whitworth is an English nut & bolt system.
markct
06-06-2003 20:54:56
well to further confuse things, pipe thread tap holes are supposed to be reamed with a tapered reamer before tapping, so there are 2 different sized drills, some books will list it as the size needed before taper reaming,and some books list a size that will work ok without reaming, i usualy dont bother to ream pipe tap sizes under 3/8 npt
Bob
06-05-2003 20:50:00
Link
