Jackson Auto darkening helmets
Farmer/Paul
06-03-2003 05:08:21
I dropped a small fortune on a jackson Nex Gen 3N1. The helmet works great, never see any amount of flash. Had another fella try it on low amp Tig he said it was great as well. ( It can be used to grind and torch cut as well)
My only complaint is clarity. There are certain positions ( tipping the Helmet in / out for out position welding) where I see ghost images. I am wondering if it is because of the gap between the front and rear Clear lens and the LCD.
Has anyone else used this helmet or experience this ghost image using other helmets
Pat/WV
06-12-2003 18:27:55
 Re: Jackson Auto darkening helmets in reply to Farmer/Paul, 06-03-2003 05:08:21
the ghost image comes from the reflection off the lens from the arc flash. its especiall bad a night if youre weldin against a wall or on the ground.
