Draining compressor best way?
tom
06-02-2003 06:20:18
How and what is the best way to remove water in the tanks of my Emglo compressor. I have a nice 7.5 hp Emglo twin tank wheelbarrow type. The thing set me back around 700.00 and I am wondering how you drain the water from inside the tanks. I usually open up the valves and let the air exhuast out and with it dirty water. Is there anyhting I can spray inside the tanks to help retard the inevitable rust?
George
06-02-2003 13:55:11
 Re: draining compressor best way? in reply to tom, 06-02-2003 06:20:18
Try this link.
thanks just ordered it!
06-02-2003 16:56:41
 Re: Re: draining compressor best way? in reply to George, 06-02-2003 13:55:11
thanks for the tip. the net is great thanks to you.
JD-Tractor in NY
06-02-2003 21:49:55
 Re: Re: Re: draining compressor best way? in reply to thanks just ordered it!, 06-02-2003 16:56:41
Wouldn't hurt to run some alcohol thru the air intake occasionally ,buy it as air brake dryer for large trucks with air brakes
Bob Tredinnick
06-02-2003 08:25:18
You can get an automatic drain unit that you install on the bottom of your compressor. It will open as needed to drain the water. I know that NAPA sells one made by a divison of Gates, the old Douglas Air compressor Co. in Alta Vista VA. I think it is about $150 or so. Might be wrong on that one.
