Tire tool
Doug Franks
05-31-2003 18:28:07
Where can I get a bead breaker or slide hammer to use on rear tractor tires???? Thanks! Doug
Scott
05-31-2003 21:26:00
 Re: tire tool in reply to Doug Franks, 05-31-2003 18:28:07
Just made one myself. Cut a steel fence post off a bit longer than your steel fence post driver is deep. Cut the rear leg off the post for about 1 1/2 inch, then at an angle up. Round the corners, and I had to cut a knob off the post. Use your fence post driver and drive it into the bead, and off it comes. Works slick, and if you have an old one bent, you may be able to recycle it.
Try NAPA too. NT
05-31-2003 18:56:29
Dave, Sherburne, NY
05-31-2003 18:44:36
GEMPLERS in Wi. they have a website too
