Smokin chain saw
Pitch
05-28-2003 20:12:31
What would cause a chain saw to start smoking in the middle of a tank of gas? I have a 42cc Poulan Pro with an 18" bar. I have been cutting a lot of brush and limbs this spring and have put a couple of gallons of fuel thru it and all has been normal. This morning I ran it for about 15 minutes and it was clear then this afternoon I started sawing again (same tank of fuel) and after about 5 minutes work it started blowing blue smoke. No change in performance sound or power just smokey. Any ideas?
bob
05-29-2003 21:49:39
 Re: smokin chain saw in reply to Pitch, 05-28-2003 20:12:31
Sure its not bar overheating because of a pinch, using motor oil instead of bar & chain oil or blocked oil filter? Bad rings, choke left on or something burning next to the muffler are only other things. Poor performance would result from first two, & last one would keep smoking after shut off.
