Well drilling
Brian
05-27-2003 19:37:33
What should the going rate be for drilling a well? I've checked several outfits and the prices are all over the place.
Central Minnesota
05-30-2003 07:48:20
 Re: well drilling in reply to Brian, 05-27-2003 19:37:33
Another question you may want to ask is; "What do you charge for a dry hole?" Some drillers around here only charge if they get you water. Others however are not quite as accomodating. Just a thought.
tortmort - $ 20.00 Per fo
05-28-2003 19:22:34
Going rate is $ 18.00 to $ 20.00 per foot here in Southern California. I had to go 500 feet, you do the math. Get 5 gallons per min. At least the water is very, very good.
Fred KS
05-28-2003 10:01:11
In '96 I paid $7.50 a foot in NE Kansas for a 6" cased well.
Hit water at 93 feet and went on down to 120 feet so the pump could sit 10' off the bottom.
Turned out to be a large aquifer that produces 400+ GPM. Of course we won't talk about the first well a mile away that produced dust and had to be filled in with gravel.
Good luck with yours.
Jerry A.
05-28-2003 06:35:39
I paid about $16 a foot for the first 100', then $14 a foot there after to get a 365' well (that price includes well casing, 6" diameter), in the western Illinios region. There are cheaper guys, but many will stop in the upper layers of sand to give you a shallow well. I didn't mind paying the higher price, as I got 15 gal/min flow. The crew was efficient and did the whole thing in about 3 working days. After seeing the equipment they use, I see why it's so expensive.
VaTom
05-28-2003 05:00:42
Hi Brian,
Here in central Va, east of the Blue Ridge, a typical 300' well goes for $2500-3000, plus pump and hookup. West of the mountains, 30 miles away, it's a whole different story due to much more difficult geology. Drillers from there don't change their pricing for this side of the mountains. One recently charged nearby friends nearly $9,000 for 400', hooked up. Guaranteed water flow used to be common here but we had a several year drought. As it's over, maybe guaranteed water will return IF competition increases.
I wasn't thrilled with the guarantee, 1 gpm, and went looking for a drilling rig to buy. We have stone to go through and I figured one of the old cable rigs that slooooowly pound their way through would be cheap enough to buy for my brief use. What I found was a small trailer mounted rotary rig with a hammer that cost what one hole in the ground would have cost, used, from a guy who'd unsuccessfully tried to get into the drilling business. I have to rent a large air compressor to make it work.
I briefly thought of drilling for others but don't enjoy it all that much. Plan now is to drill two more wells here and send it along to a new home. In all probability I'll make a substantial profit on the resale and get 3 wells thrown in.
Not knowing your capabilities, free time, or geology, I wouldn't suggest your buying a rig, but it sure worked out fine for me, after I looked into it carefully.
Good luck.
Tom_NC
05-27-2003 23:15:28
As with most things I am sure it varies by where you are. Here in western NC my brother just had a 6" well drilled and it was $7.50 per foot. 565 feet later he had 10GPM which will be plenty for a single house. I don't remember off hand how much it was to install the pump and tank. If you do end up replacing the current pump do yourself a favor and go to a submersible.
John A
05-27-2003 19:46:17
Brian, Here in central Texas, + - $5.00/ft to drill + - $5.00/ft to case ----- - + - $10.00/ft total
Good Luck,
John A.
dg
05-28-2003 06:13:02
 Re: Re: well drilling in reply to John A, 05-27-2003 19:46:17
Well John I must of got taken for a little bit of a ride. I just dug one last month in Limestone co. I did a little pricing around and it was the best deal I could come up with. Some diggers wouldn't even touch it, or wanted to charge me by the hour, ha ha! I got a 440' well, slab, pump, tank, the whole deal. We started with a test well at $5 a foot, when all the smoke cleared, the whole deal turn key was $6800. I ain't complaining, I was just great full to get a well. 10-12 gpm, a little off taste, no smell, I can drink it, that's all I cared about.
John A
05-28-2003 18:32:18
 Re: Re: Re: well drilling in reply to dg, 05-28-2003 06:13:02
dg, My figure is for drill & case only. Not counting pump,wire,pipe or any thing that could be called a well house. Your price doesn't sound that far out of line, if any. Here on the west side of williamson county most new wells are 500 ft deep depending on where you are, and whether or nor it will smell or taste bad.
Price had been 8&8 before the economy went south 3 yrs back
Good luck with your new well.
John A.
dg
05-28-2003 19:33:29
 Re: Re: Re: Re: well drilling in reply to John A, 05-28-2003 18:32:18
I have to agree with ya John A., I think your pretty much right on the money. I was quoted over the drill& case about 1500 for the rest of it. It came in a bit higher than that according to my math, but like I said, I ain't complaining. I was just greatfull to get a well with water I could drink. Take care.
Burlgoat
05-28-2003 16:43:54
Hey DG! How ya doin'?
Who drilled your well? We're thinking about drilling our own well, and we're in Limestone County on the east side of Lake Limestone. Sounds like a good deal you got! $6800 for a turn-key job...did that include pump, electrical and guaranteed water?
dg
05-28-2003 19:26:26
 Re: Re: Re: Re: well drilling in reply to Burlgoat, 05-28-2003 16:43:54
Doing fine Burl thanks. I used Double J water well over at Thornton, talk to Jimmy Lenamen 254-729-3762. Nice guy, seems to be pretty straight and knows what he's doing. Tell him you heard bout him from David Hall over on 14. I think he was real fair with me but I ain't making no promises. Hope your as blessed as I was. There's no guarante on the water but he'll punch a hole to see for 5 bucks a foot, like John says. My price included pretty much everything except the well house of course. I wanted good stuff, all my electrical is square D and I think they make good stuff. He'll only pour a 4 1/2x6ft pad. You might get em to do a bigger one but be ready to pay for that. You shouldn't have any problem with water. Your on the good side of the county, course you never know with a well.
