Two Cycle Engine
Peter (NY)
05-27-2003 06:26:58
I was given a 1980 JAG 3000 F/C snowmobile over the weekend. Hasn't ran in two years. It has the AF34A2 engine (340cc oil injection into the manifold). It has spark and the plugs are wet. Tapeing the throttle open a bit, I did get it to start....once. Smoked like crazy and had a puddle of oil coming out of the exhaust. This thing just doesn't want to start. My question: Does anybody have any good links on fixing this thing? It's a good tinker toy. Any help is appreciated. Thanks
P.S. I did disassemble the carb and clean.
Peter(NY)
05-29-2003 06:01:16
 Re: Two Cycle Engine in reply to Peter (NY), 05-27-2003 06:26:58
Thanks everyone! It looks like a rainy weekend. I'll give it a try.
Skinner
05-28-2003 20:06:34
First, drain the gas and replace it with fresh gas. Oil fouling is usually due to bad fuel. Try this and let it run for awhile. If it's still sluggish then clean the carb or injectors.
rod
05-27-2003 09:36:50
2cycle that sat for 2yrs. Probably stored with gas in it. Your carb is gummed up. To do it right, remove the carb, complete disassemble, clean, clean, clean, blow air through it. Good luck.
bob
05-27-2003 11:23:13
 Re: Re: Two Cycle Engine in reply to rod, 05-27-2003 09:36:50
My daughter had a ? 72 Polaris that acted like that and I found a drain plug at the bottom of the crankcase. It was filled with water. After I drained it,it ran.Hope this helps.
Tom_NC
05-27-2003 23:19:11
 Re: Re: Re: Two Cycle Engine in reply to bob, 05-27-2003 11:23:13
Water in the crank case! How long did it last after that?
bob
05-28-2003 08:05:08
 Re: Re: Re: Re: Two Cycle Engine in reply to Tom_NC, 05-27-2003 23:19:11
It was not used a lot,but it lasted about 3 years and was still running till it was sold.The plugs did not water foul after that.
