8n rotavator
Larry
05-25-2003 20:03:57
Ijust purchased my first tractor, an 8n in good shape. Today I tried to rotavate a plowed field and managed but it was difficult.Does anyone think that a 5' rotavator is too large for this tractor? First gear seems a little too fast for travelling.
Robert in W. Mi.
05-26-2003 06:39:46
 Re: 8n rotavator in reply to Larry, 05-25-2003 20:03:57
I never owned a 8N or rotavated with one, BUT i do a lot of custom rotavateing. I own (3) Howard rotavators at this time. Maybe this doesn't apply, but the "real" problem here is power! Most think you need a very slow ground speed to rotavate, but the truth is you need a FAST tine speed so you can go faster!! The problem with that is, it takes a LOT more pto power as you turn the tine speed up!
A rotavator will work well in "any" soil!! You just have to set up the rotavator for those conditions!! As i do custom rotavateing, i run into all kinds of soil from blow sand, glacial silt, gravel, mud, hard packed clay and everything inbetween!!! It's all in knowing what your customer wants/needs!!
Bottom line is, you need more power!!
Robert
Dell (WA)
05-25-2003 21:28:48
Larry..... ...every springtime the YT N-Board gets this same question "Why can't I rototill with my N-Tractor", and the answer is always the same, the N-Tractor is too HIGH SPEED ground geared (as you found out). Unless you can find the rare and fragle "Howard" after tranny aux gearbox $$$ yer outta luck. The more common dealer installed "Sherman" aux trannys slowdown the PTO rpms too much.
Howsomevers, the 8N is a 2-bottom plowing fool, its just not a fool about rototillin'
Remember the rototiller was invented AFTER the N-Tractor was designed and was designed for ENGLISH soil conditions to be used with the Ferguson TE-30. (equiv to 8N). Remember, its the 1939 Ford/Fersuson System that set the cat-1 3-point standards, now used world wide..... ...Dell
JoeK..Dell
05-26-2003 04:59:37
 Re: Re: 8n rotavator in reply to Dell (WA), 05-25-2003 21:28:48
Though I bow to your knowledge of Ford Ns etc and value yor advise greatly a thought just popped into my mind.Could the ground speed differential involved here be solved with perhaps a smaller set of rear tires wheels,used specifically for rototiller appl.For years we have flipped/reversed/reset the track for different tasks such as cultivation.It seems that it would be no harder to switch out a set of 16-20" or so rims with suitable size rubber for this task as maximum traction/flotation is not the issue,but simply carrying/operating the tiller.
Your thoughts please.
JoeK..oops
05-26-2003 05:05:31
 Re: Re: Re: 8n rotavator in reply to JoeK..Dell, 05-26-2003 04:59:37
Dell,info on what I'm thinkin here is prolly out there in Nland,What were the gearxgear groundspeeds on regular Ns vs the BNO-25/40 Tug models with truck size rear wheels/tires?,Must be in print somewheres,ya think?
Dell (WA)
05-26-2003 11:25:49
 Re: Re: Re: Re: 8n rotavator in reply to JoeK..oops, 05-26-2003 05:05:31
Joe..... ....I am under the impression that the millitary aircraft tug versions (BNO-25 & BNO-40) of the 2N Ford Tractor used the same 6.66:1 differential pinion and ring gears. Which rummor has was off the 1 1/2T Ford medium duty truck. The BNO's rear brakes were hydraulic operated, while the tractor and Ford automobiles were mechanical brake operated. The BNO-25 used a single rear tire and the BNO-40 used dual rear tires. Both used small diameter front tires, not tractor based tires. Large diameter tires are used for ruff-offroad applications, runways are usually preety smoothe.
Rummor also has it that they actually shipped back to the States, alotta aircraft tugs that were then re-converted to agriculture tractors. And they dumped good airplanes and jeeps into the ocean, go figger..... .....Dell
JoeK
05-26-2003 12:15:01
 Re: Re: Re: Re: Re: 8n rotavator in reply to Dell (WA), 05-26-2003 11:25:49
What Im gettin at looks like this,at 2000rpm engine speed if top gear was 1:1 into a 6:66 differential a 40"(overall)tire would equate to appx 35mph groundspeed.Given all factors the same vehicle with a 30"(overall)tire would be at appx 26mph,regardless of tread design or wheel size.For instance I believe WillyN is running some 16"rim Ag "floaters" on one of his tractors,though overall tire height is similar to the original size.With the vast number of sizes/styles/profiles of tires/rims available these days,it might pay to experiment a bit.However,like swapping cycle sprockets(same idea)a trade off is made ie speed lessens power,power lessens speed.Just wish I had a Sherman hi/lo N and owned a tire shop...lol,Somewhat scary is the fact that a Sherman hi N with taller(ie 50" tires)should clock close to 50mph IF you had enough engine torque to get em up to speed and "big brass ones".
Dell (WA)
05-26-2003 17:07:37
 Re: Re: Re: Re: Re: Re: 8n rotavator in reply to JoeK, 05-26-2003 12:15:01
Joe..... ...understand where your coming from. Might work with the 8N's smaller 11" brakes but would definately NOT work with the 2N/9N's larger 14" brakes. Somewhere I seem to remember the Howard after tranny had about a 4:1 reduction. So you'd need to get a rear tire/rim combo that would reduce your 8N ground speed by a factor of about 4 as compared to the OEM 10-28. Might be do-able if'n you was inclined to 'spiriment.
Of course there is this other direction to consider. Back in 70's, down around Lodi Calif, used to see N-Tractors draggin' an air cooled AUX ENGINEED 3-point mounted rototiller thru the grape vines. Don't know 'nuttin' more. Make of rototiller, nuttin'. Could have been a local machine shop fabrication, I wasn't interested at the time..... ....Dell
Larry
06-02-2003 18:41:18
 Re: Re: Re: Re: Re: Re: Re: 8n rotavator in reply to Dell (WA), 05-26-2003 17:07:37
Thanks for all the advise guys, but it makes sense that someone said that these 8n's never had a rotavater attachment. So I'll experiment with speeds or go back to square one and plow, disc and harrow.
