Can anyone ID this small DeVilbiss diaphragm compr
Robert
05-25-2003 17:23:03
third party image
I hope I have my terminology correct there. Unfortunately someone removed the tag from this little pump so I cannot tell what it's purpose was. Does a fine job on tires. DeVilbiss can't help at all. Would be very grateful for any info. Thank you.
Rusty Jones
06-03-2003 13:20:28
 Re: Can anyone ID this small DeVilbiss diaphragm c in reply to Robert, 05-25-2003 17:23:03
Your DeVilbiss compressor brings back many memories! I had a similar compressor, called a Brown, worked on the same principle as yours! You must use a "bleeder" type gun with it. This type of spray gun "bleeds" air when you stop spraying, then the air goes back to the nozzle when you pull the trigger again. The bottom of the cup will be concave, to take care of the pressure. I used a Binks Roche' gun with mine. It had a little bleeder hole under the inner nozzle, which had to be kept open. Failure to keep the hole open would result in the bottom of the cup becoming convex, with the ensuing problem that you couldn't set the gun down--it would roll over! Well after hammering the bottom back up to where it was supposed to be, the metal got weak and finally split. I always kept a small drill bit to clean out the hole, twirling it with my fingers. I did some touch-up body work/ painting, with automotive type paints. Did a nice job!
JoeK
05-26-2003 04:47:05
The present DeVilbiss Co is a product of several company offshoots,mergers,aquisitions,separations etc since originally in business.A few years back when researching a 40s era Devilbiss,I was referred to a Canadian Co called Deville-Aire or such as the Co/division I was seeking.They were able to answer my ?? and point me at a US service center who was familiar with my unit and had parts I needed.
Now if I can locate my notes,I'll post back the particulars.
Robert
05-26-2003 00:07:20
third party image
Thank you for those comments. As you gentlemen said, it must be old, not just from the style, but the quality. I would like to find out what kind of spray equipment would work with it. I understand motors can be dated from the code letters so here is a photo of the engine plate if it helps? Thanks again.
John in MA
05-27-2003 21:30:29
 Re: Re: Can anyone ID this small DeVilbiss diaphra in reply to Robert, 05-26-2003 00:07:20
Give GE a call. They keep records of their motors dating back to the beginning of time.
Bleeder-type spray guns and similar design airbrushes were used with these. Add a small tank and an adjustable popoff valve and you can use better types.
John in MA
05-25-2003 21:04:25
It's for a small spray gun or airbrush. Every's been making this general type of compressor for years, although yours looks ancient.
Dr Cy Kosis
05-25-2003 17:43:06
I cant tell you the model number but I can tell you its OLD.
I grew up in my Dads shop from a toddler on, and have fond memories of some of the tools and equipment that he had.
He had one of these compressors and two others, larger and HUGE. When I was little the one like this one was already old and well used and that was over 35 years ago. According to my Mom's recollection he bought it used in 1957.
It is definitely a diaphram type, because I remember it torn apart once for a rebuild. He used it regularly with a small pressure cup spray gun and also for air brushing. I thought of that old De Velbiss recently and wished I had it still just because it stands out so vividly in my memories. That one was sold at auction after my Dad's death in 1976.
