Can a fuel oil stove use #2 diesel?
Bob G
05-25-2003 08:08:18
I bought a used fuel oil heater for use in my shop, it is recommended to use fuel or stove oil. I have access to #2 that I can get quite a bit cheaper. The question is can I use #2 and will the stove work right with it?
Thanks Bob
ron in ny
06-03-2003 21:22:41
 Re: Can a fuel oil stove use #2 diesel? in reply to Bob G, 05-25-2003 08:08:18
Good question, would love to keep just diesel to run torpedo heater and kersene lamps. Any one got experience with these?
G Taylor
05-28-2003 08:51:00
Use low sulphur so it doesn't stink the shop up and damage your respiratory system with sulphuric acid compounds.
JMS/MN
05-26-2003 23:11:23
There is no difference between #1 diesel and #1 fuel oil, or #2 diesel and #2 fuel oil. Kerosene is different, like distillate.
Dusty
05-25-2003 17:18:51
Is this heater a gun or pot type heater? If it is a pot type heater you had better use #1.
Dusty
rustyfarmall
05-25-2003 10:13:18
There is very little if any differance between #2 diesel and regular heating oil. The only thing you would want to watch is if you live where it gets cold in the winter, don't store the #2 outside, if this is the case, you can still go with #1 or a winter blend.
Chris
05-25-2003 08:32:16
I have used diesel in my torpedo heater a time of two. Slightly more odor than kerosine but it worked OK.
