Trailer lights
lc
05-21-2003 19:30:58
I have a common 5X8 trailer that developed trouble with the lights. I replaced everything. They still don't work right. It has 3 wires. One to left blinker, 1 to right blinker, one to the tail lights. Any of them will work separately. BUt if you turn on headlights, then press brake pedal, all lights go out? What am I missing? Should be so simple. ??
John A (Va)
05-22-2003 04:10:32
 Re: trailer lights in reply to lc, 05-21-2003 19:30:58
What Chris and mrx said. The connection of the trailer to the vehicle does not always provide a sufficient ground. You need a separate wire (white) that connects to the trailer frame via a bolt or screw.
JA
Chris
05-21-2003 21:16:59
Like mrx said you are missing the ground wire . there should be 4 wires not three.
mrx
05-21-2003 20:18:43
ground
lc
05-22-2003 05:49:16
 Re: Re: trailer lights in reply to mrx, 05-21-2003 20:18:43
THanks, I will try that. There is a 4th white ground wire. Short. Doesn't go anywhere. I have looked at new ones, they are the same way. I will try attaching one to see if that works. My meter does suggest current is bleeding over to the other wires. Thanks again.
RWK in WI
05-22-2003 18:49:07
 Re: Re: Re: trailer lights in reply to lc, 05-22-2003 05:49:16
A quick / temporary way to test is to use a single battery jumper cable - one end clamped to a bare / unpainted bolt on the trailer and the other end to a clean connection on the pulling vehicle. This quick fix has limped many a trailer home with legal lights.
lc
05-22-2003 19:20:07
 Re: Re: Re: Re: trailer lights in reply to RWK in WI, 05-22-2003 18:49:07
THanks guys, a good clean ground wire fixed it. They now work like they should.
John
05-23-2003 10:22:10
 Re: Re: Re: Re: Re: trailer lights in reply to lc, 05-22-2003 19:20:07
Ah yes!.. you must have a ground, or is it an Earth...or as we called it when I was a welder, A Land Wire.
