Battery restorer
Tom
05-20-2003 19:19:24
I remember buying a bottle of solution that restored and lengthened the life of 12 volt batteries. Does anyone know where to find this? I don't remember the product name but it was available in auto parts stores 25 years ago
Get a NEW Battery
05-24-2003 06:17:18
 Re: Battery restorer in reply to Tom, 05-20-2003 19:19:24
problem solved.
Nolan
05-23-2003 05:55:21
I've had decent luck with dumping the battery, washing it out with running water(you'd be amazed at the crud and chunks that come out), adding fresh acid (cheap btw), and charging it. I've gotten several years out of batteries that way.
Slowpoke
05-26-2003 00:23:21
 Re: Re: Battery restorer in reply to Nolan, 05-23-2003 05:55:21
Are you getting acid from a battery shop? How cheap was it? I bought some about 15 years ago and used it up. The shop is gone, and the another place says battery acid is no longer sold. Probably due to misuse or environmental.
Well, that's California.
JJBUTSON
05-22-2003 19:20:49
My dad has used plain ordinary asprin for that for as long as I can remember and it don't seem to work to bad. I think he puts about 10 in each cell and tops off with tap water. seem to get another summer out of a tired battery.
Ben in KY
05-21-2003 11:48:19
I have tried a couple of these kinds of things in past years. Improvement was marginal at best and not for long. I thought they were a waste of money.
Ludwig
05-21-2003 10:57:04
Better than "magic liquid" is a battery desulfator. I bought my solargizer on eBay and it totally reawakened the tired battery in my pickup. It added probably 3 months over when I would have replaced the old battery. I finally did replace it because I thought it was totally tweaked at 6 years old, but the new one was no better! I finally replaced the starter and the slow cranking problem is solved... Wish I hadn't swapped the battery now.
Fred OH
05-21-2003 10:09:47
I think it was called VX-6...don't know if it is available now or not. Had a brother in law that said to use baking soda to awaken a tired battery...didn't work...and had a mountain of snow looking stuff on top of battery. He had a deadbeat/red faced look on his face to boot. L8R....Fred OH
frito
05-21-2003 14:05:12
 Re: Re: Battery restorer in reply to Fred OH, 05-21-2003 10:09:47
VX-6 is the name and is sold by J.C. Whitney
Tom
05-21-2003 10:41:48
I don't think mixing acids with a base is such a great idea, Yikes ! Thanx for the reply
Ray.IN
05-20-2003 19:32:26
"Charge-it" from Solder-it. Inc. PLeasantville. NY 10570 is one mfgr. Not a plug, just an answer to your question.
