Glass cutting
Carol Martin
05-20-2003 14:02:27
I am sure there are experts on here that know all about glass cutting.. Is there a way to reliably cut old window glass?. I have cut new glass with no trouble but old glass just seems to have completely changed properties and will not break on the score the way I think it should.. If there is a trick to it I sure would like to know.. I have plenty of old window glass and hate to go buy a new piece when it would be simple to cut one to the size I need..
Thanks
Carol
Brian
05-24-2003 04:27:41
 Re: Glass cutting in reply to Carol Martin, 05-20-2003 14:02:27
One important thing.... make sure the glass is clean.
Nolan
05-21-2003 05:15:58
Under water, with sheers.
Murph
05-20-2003 14:22:03
Carol, Make sure your glass cutter wheel is free and turns easily. If not free it up if possible so it won't skip when run it across the glass. I also have a small paintbrush with kerosine on it that i run along the straightedge before I run the cutter along it. Old glass is harder to cut but with a good cutter, lubrication, and firm steady pressure you should get more good cuts than bad.
jake
05-20-2003 16:55:02
 Re: Re: Glass cutting in reply to Murph, 05-20-2003 14:22:03
I use a carbide tipped scribe for making the mark there is a deep cut and breaks cleanly.
VaTom
05-20-2003 19:56:11
 Re: Re: Re: Glass cutting in reply to jake, 05-20-2003 16:55:02
Wow Jake,
If that carbide tipped scribe makes for successful cutting of old glass, especially thick old glass, I want one. Where'd you get it? Or is it something you made? I do OK, with a good wheel and lubrication, up to 1/4" but not after that.
