Oxy-Act Cart ideas
Mark (PA)
05-20-2003 06:17:28
Hello ALL Been reading lots of good tips for the oxy-act and welding techniques lately. Thought i'd throw this out there for some help. I just bought a new cutting/welding torch outfit. Curious if any of you have made a home-made cart for the bottles, hoses, and tools. I have an old Sears LT10 riding mower chasis that I thought of somehow converting into a nice cart. Usually see people using dolly's for this application. I'm wondering if being on a farm an all if it wouldn't be better to make it pulled with a lawnmower or quad? Or stick with the by hand method for moving it around the farm? Any input on which method or moving device is greatly appriciated. If any of you have pics of your carts please post!
Mark
Chances R
05-20-2003 18:54:00
 Re: Oxy-Act Cart ideas in reply to Mark (PA), 05-20-2003 06:17:28
I will assume tht you bought a pretty large set of tanks. My brother and I built a verticle style cart a few years back. We took a tractprs 3 point hitch removable drawbar and custom fitted it to the cart. and then made a area for a top link hook up. If we so desire we can mount it to the back of a tractors 3 point hitch. The drawbar can be removed from the cart. We used air filled tires that were about 12" diameter, and they role nicely.
Unimog
05-20-2003 09:42:56
I used a hand truck I picked up at Sam's Club for
$30 and welded on hooks to hold the hose and a
chain setup for the tanks. Also had to enlarge the
lift point with angle iron to hold tanks. Rolls
easy with 8" air tires.
Unimog
T_Bone
05-20-2003 09:10:03
Hi Mark,
I like carts with the 24" wheels for farm use. Any smaller than that and it makes moving them on soft ground a workout where the big wheels will roll great on soft ground.
I take a piece of 1"x1"x1/8" angle iron and reinforce the verticle pipe then weld a 3/4" pipe horizontial about 2" lower than the acetylene cyl top. I "v" votch the 3/4" pipe then kick it about 15* then weld too the 1" angle iron. The pipe is about 2" past center line of each cylinder.
I weld a 1/4" chain hook about 4" from the cyl top. I weld a pice of chain to hold the cylinders on the 1" angle iron. Cut the chain so it goes around the cylinders, weld in center of chain, and easy put on the chain hook.
What the chain does is tighten around the cylinders by falling towards the bottom when the cart is moved sucking the cyl's tight against the cart bottom and 3/4" pipe so you don't fight loose cylinders when you move the cart. Too loosen chain just slide up the cyl's then remove from chain hook.
For hose hanger I use a piece of No4 rebar (thats 1/2"). I bend a "U" so it's fits around the o2 cyl cap threads and make a curved piece to fit the cylinder with two "U's" spaced about 14" for hose wind up. This lets me easy and neatly remove my gauges, hose and torch when I want to leave the bottles outside.
I never put on a "trash" box for storing tips and such. The tips get beat up and trash gets put in the box.
T_Bone
Fred OH
05-20-2003 09:48:57
 Re: Re: Oxy-Act Cart ideas in reply to T_Bone, 05-20-2003 09:10:03
Sounds pretty good but I always put a box on the ones I build...I never have to hunt for my chipping hammer or take time to go get another tip or change to the cutting mode, a lid on it is just fine. (with a latch) Another thing that I always build into mine is to have an eye at the top to lift it up with a hoist to load it into a truck and a way to put a cable hoist around it to hold it in the standup position next to the cab. This is the safest method of transport. The newer cheap carts can do pretty good for running it around the shop...but if you try to lift them with a hoist...they are made too light and the frame will bend, (I use all large cylinders.) The 24" wheel idea is good...but they should be old garden plow wheels made out of steel...a pneumatic wheel (air in it) will ruin if it runs over a piece of hot metal. Just be sure to make the cart so it will not fall over...you only want to see one bottle rocket through the air. Keep the caps on while transporting. L8R....Fred OH
john
05-20-2003 07:49:57
Mark,
try this site... lots of plans for carts for o/a mig, tig, etc...
john
http://www.hobartwelders.com/mboard/forumdisplay.php?s=05ab321bbd5d9d1589cdc12651d8a208&forumid=5
Errin OH
05-20-2003 07:02:20
Dolly? Mount that sucker to the rider and fix the engine.
The best dolly setup I have seen was a friends. His tanks set front to back instead of side by side. Nice and narrow. Large 8" wheels. Had hooks on the sides for hanging hose and such, but could-a used a little box for small stuff like tips and cleaners.
CWL
05-20-2003 08:05:21
 Re: Re: Oxy-Act Cart ideas in reply to Errin OH, 05-20-2003 07:02:20
I have one of the carts that the bottles set front to back. It was made by Harper Truck in Wichita, Ks. It is the best torch cart that I have seen for balance and maneuverability. I have also seen side by side torch carts that have a set of fold up wheels in the back. When they are folded out the cart rests on them at about a 30deg angle. Works good on smooth concrete.
Robert in W. Mi.
05-20-2003 06:51:55
Best idea i've had for one in a long time was to order one from Harbor Freight!! It has big wheels and is plenty strong. $39.00 and they paid the frieght! I wouldn't bother building for that! Robert
Peter (NY)
05-20-2003 06:24:16
Hi Mark,
I built one from and old dolly. I have the small plumbers acetylene and an 80 cu ft O2. I like to have it on the dolly for ease of manuverability. I've had to use it more than once in a cellar where I had to go down and up the stairs.
Chester
05-20-2003 16:00:09
 Re: Re: Oxy-Act Cart ideas in reply to Peter (NY), 05-20-2003 06:24:16
Also have that 'B' tank and 80 cu. ft. oxygen tank, which sit together with the 'B' tank in front. Along the side is a rack to hold the tips, hooks on back hold the hose, 1" vertical pipe on other side holds full rods and another shorter pipe holds halves or stubs, a hook holds the striker. Looks like a small hand truck about 38" high handle and 24" sides. Sits easily under a bench until needed. Only has 8" wheels as it moves around on pavement.
