Barrel deheader
carl
05-16-2003 16:41:20
For years I had a hand operated tool that cut out barrel tops and left a nice smooth edge. It disappeared and I now desperately one? Does anyone have a source? The tool dealers here in the Tampa area don't know what one is;help is appreciated.
JoeK
05-16-2003 19:46:39
 Re: barrel deheader in reply to carl, 05-16-2003 16:41:20
www.Gemplers.com has em,and replacement blades
Steel Drum De-header Tool
Item No. W937
In stock? Yes
Qty Price 1 - 2 $57.50 3 + $50.95
ajco
05-16-2003 19:28:06
A muffler remover tool in an air chisel does agood job &is as fast as you can push it.
KEG
05-16-2003 18:50:00
CAUTION - Cutting barrels with a torch can be a quick way to die! They easily explode depending on fumes inside!
Try Labsafety.com under the term "drum deheader" Here's a link to three different tools:
Link
hjp
05-16-2003 18:48:34
northern tool sells one,page 179of their old catolog #172.
item #1550-c172 for $44.99 and s+h
extra blades are $9.99
I allways use poly.
take care !!!
carl
05-16-2003 18:17:38
This tool cuts the end from 30-55 gallon drums,NOT cutting the ridge from cylinders on engines. If you ever hauled feed in drums cut with a chisel you will appreciate it.
glen
05-18-2003 18:12:58
 Re: Re: barrel deheader in reply to carl , 05-16-2003 18:17:38
If we didn't have the drum topper, in the oil business we used to use a pipe wrench and a good hammer. Put the jaws over the edge of the drum with the handle sticking out. Hit down on the front jaw with the hammer. Just keep working around the drum. Keep the jaws tight so they just fit over the edge. The purist will probably not like the improper use of the wrench, but it sure beats trying to use a chisel. Gives a cleaner edge also.
Richard Fazio
05-16-2003 17:40:23
Are you talking about a cylinder bore ridge reamer? I've got an old one I've used a few times. Don't know if they still use them as a regular item. I bought mine 30 years ago at an auto parts place. It's an Ammco Ridge Reamer, Model 2100, Ammco Tools Inc, North Chicago, Illinois. I Did a search on the web and came up with tons of links. It appears they are still in business. Ammco Tools, Inc. 2100 Commonwealth North Chicago, Illinois 60064. I'm sure there are many other manufacturers of ridge reamers also.
Jim
05-16-2003 18:36:25
 Re: Re: barrel deheader in reply to Richard Fazio, 05-16-2003 17:40:23
I know what you mean about the chisel -bad news. I cut out my steel barrel heads with my torch.i also can blow vent holes in the side while i'm at it.burn barrels. no sharp edges.i always wear gloves when i handle them anyways.
