Hi Fred: I have had limited experience with non detergent, non compressor oils. I have seen people using a product from Esso (Exxon) called Mineralube, and it seemed to work well. If regular, non detergent oil has worked for you, I don't see why you shouldn't keep on using it. Keep in mind, however, many compressors take oil vapor in from the crankcase to help lubricate the valves, so there will always be some oil going into your head, usually. For me, it is worth the little bit extra to get the proper compressor oil, it really is formulated to meet the specific needs of compressors. I have seen first hand how badly carboned up compressor cylinder heads can be when improper lubricants are used, especially heavy 15w40 engine oils. Additives designed to clean the engine from deposits seem to be the culprit, ironically. Are you familiar with AMS oil synthetics? We use their compressor oil in many of our gas driven units. It is good stuff, excellent hi-temp charachteristics, and pourable at low temperatures, but I would only recommend it for a machine that is thoroughly broken in. Synthetics can interfere with proper run in by being TOO slick,(I have seen it happen to two units I built, lesson learned). Sometimes it doesn't allow enough friction to break in rings and such. No matter what you use though, change it regularly, any oil will get sludgy after awhile, and infrequently used compressors tend to get condensation in their oil, like any machine. Oil is a major profit center for many compressor companies. I have seen companies selling their big compressors practically at cost and then tying their customers into 2-10 year warranty agreements that can only be validated by using their name-branded oil exclusively. I have seen compressor oil from $150 for 5 gallons up to $900 for 5 gallons. Sure, it is good stuff, but it does get a bit laughable at times. AMS oil should be available in 1 litre, oops, 1 quart jugs, from any AMS oil dealer. If you can't find AMS oil, compressor oil available at most hardware stores should do just fine. Bye!
