Spray power torch
ken in la
05-13-2003 18:28:48
my friend died and is kids gave me an eutalloy model B torch.this is a whole set up. it has a cutting torch and awelding torch with diffewrant tip and a spray power torch.little cans of power, is it worth any thing.what can i do with it,
Steve U.S. Alloys
05-14-2003 06:26:15
 Re: spray power torch in reply to ken in la, 05-13-2003 18:28:48
Ken, be sure to keep the lever tied down on that B torch. If you store it for long periods with the lever up..... .the feed valve will take a set and it won't spray.
The valve is located in the front of the torch under the hopper. You'll see what looks like a standard screw head there. If you unscew that, the rubber valve will be right there. The valve is keyed so it won't go in wrong. If the torch won't spray, that valve is the culprit more than likely. Light may still appear through the hole but if you compared the old valve to a new one by looking through the hole, there would be a considerable difference in orifice size.
Steve
Farmer/Paul
05-14-2003 02:01:54
There are some posts on powder torches about 10 posts before this one.
