Makita drill, how to remove chuck
Mike S
05-11-2003 07:46:00
I have a 12 volt Makita drill, model No. 6011D. I need to remove the chuck. There is no screw in the bottom of the chuck like on some drills, no allen head or torx either. So what is the trick to removing it?
Thanks
Ben
05-11-2003 10:23:59
 Re: Makita drill, how to remove chuck in reply to Mike S, 05-11-2003 07:46:00
Mike: There was one there when the drill was new , but over time some one for got to replace when the took it out last(the factory puts loktite on them so the dont't back out when reversing the drill). So now back to your original question. If you can close the chuck put a 3/8 allan wrench (short end) in chuck tighten down, put drill in LOW gear,lay down on table or support in vice (without crushing) and smack allan wrench with a mallet or a block of wood counter clockwise to spin the chuck off of the spindle, if you can't close the chuck you may need a large pipe plier to grip body of chuck. Your new chuck should come with a new LEFT handed threaded screw to replace your lost one. The spindle thread is a 3/8X24 for that drill.
Good luck
rod
05-11-2003 10:13:58
Last time I did one like that, put a big allen wrench in the chuck, then whacked it with a hammer to unscrew it.
