Superweld and an easy way to make your own gaskets
deano
05-07-2003 19:55:56
I was wondering if anyone knows where i can buy superweld,,,i live by duluth, and can't find store that carries it...also what is an easy way to cut out./make gaskets...thanx...
mj
05-08-2003 15:21:59
 Re: superweld and an easy way to make your own gaskets in reply to deano, 05-07-2003 19:55:56
Ditto on what Deas Plant said (I almost always use that method) and....with really thin gasket material like for an oil pump cover, 4wd front hub, etc. you can place the material over the part and then hold a wooden pencil at a slight angle and run it around the outside edge of the part. The paint on the pencil will rub off on the paper leaving you a line to cut to...use a ball bearing for the holes. A lot of motorcycle makers have done away with gaskets for parts like cam covers and just use a compound between the machined surfaces...I really have good luck with Yamaha's 'Yamabond' though Suzuki, Honda and Kawasaki all have similar products..... . :-)
Ben in KY
05-08-2003 06:55:20
I coat one surface with a thin layer of grease, then press a piece of manilla folder up against it. Then use an exacto knofe to cut out the gasket. Check the fit and trim as necessary. then transfer it to the proper gasket material and cut with an exacto knife. I write the gasket id/part number on the manilla template and file it away for future use in making another one when needed.
Fred KS
05-08-2003 05:50:45
See the link below for an online source for Superweld. I know nothing about the supplier. I Just did an Internet search for "Superweld" and it popped up.
Deas Plant.
05-07-2003 23:45:27
Hi, Deano. I can't help you with the superweld --
the Gold Coast, Queensland, Australia's a bit far out of Duluth for that -- but I do have a good way of cutting gaskets.
Assuming that you can get to one or the other of the surfaces to which the gasket will be fitted, place your gasket paper over the surface, use either the ball end of a ball pein hammer or an old ball bearing ball to locate the various bolt holes by pressing into them and then gently tap the paper over these holes to cut it. I like the ball bearing ball for this as you can hold it in the depression and tap it with a hammer and you don't have to be quite so accurate with the hammer, always bearing in mind that your fingers are often somewhere in the same vicinity.
Once you have a couple of bolt holes located and punched out, you can insert bolts to stop the gasket paper from moving. Then simply tap around the inner and outer edges of the gasket face to cut the paper to the exact shape required.
If you have any doubts about getting it right, have a practice run or two with newspaper first.
Where one gasket face is a flat plane as in a cover over a filter housing or similar, it is better to use the other face as the template if possible and cut the center out of the gasket as well. This reduces the possibilty of fragments of gasket paper ending up in the system.
Hope this helps.
You have a wonderful day. Best wishes. Deas Plant.
hay
05-08-2003 03:58:51
 Re: Re: superweld and an easy way to make your own gaskets in reply to Deas Plant., 05-07-2003 23:45:27
very good information. only thing i do different is i use a old rubber mallet that hardened with time and it won't damage any metal edges by tapping too hard. never heard of the superweld. maybe it's like JB weld?
Deano
05-08-2003 05:22:46
 Re: Re: Re: superweld and an easy way to make your own gaskets in reply to hay, 05-08-2003 03:58:51
I bought this stuff called superweld cause someone recommended it to fix gas tank leak. cant' remember who or where bought it from....on the gasket question what works good to cut out precision holes and shape..thanks for the tapping the impression ideas,,but in this case i could..i had to make a gasket for small engine carb...by the way thanx aussies for supporting the USA...Deano
fred kobs
05-11-2003 04:49:59
 Re: Re: Re: Re: superweld and an easy way to make your own gaskets in reply to Deano, 05-08-2003 05:22:46
If you want precision holes, you need a set of hollow hole punches. Just make sure you always have a block of wood underneath you when you hit them w/ the hammer. I have a set of el-cheapos that have lasted for 3yrs. now. Got them at Harbor Freight for about $10 I think.
