Lincoln Gas Welder SA-200
Richard Fazio
05-06-2003 12:34:27
I've got a Lincoln gas powered welder model SA-200. Lee, you said it cost you about $450.00 to overhaul yours. What did you actually do? Mine needs to be bored out, new pistons & rings, and the exhaust valves are all stuck. I'll probably need vavle guides and valves. I haven't even gotten to the lower end yet. I'm hoping it's ok down there. It is a continental engine and there is hardly any ridge at the top of the bores. It just siezed up from sitting.
JIMMY TURNER
12-17-2003 20:14:28
 Re: Lincoln Gas Welder SA-200 in reply to Richard Fazio, 05-06-2003 12:34:27
Where can I buy magnita parts. Need mag cap and rotor. THANKS>..... .....
Tom
11-25-2003 15:16:47
looking for a motor or block for a lincoln shield arc welder has a gray marine alaska lugger 4cyl in it, but the block is cracked.
