Welder question
Bandit
05-05-2003 19:00:35
Hey, I'm be now stretch experienced. Can you cut with an arc welder? A stick welder in particular? Also, which do you guys prefer stick or wire feed? Thanks a bundle...
James In MO
05-06-2003 16:11:36
 Re: Welder question in reply to Bandit, 05-05-2003 19:00:35
Yes you can cut with a stick welder but you really do not want to do this with a 10% duty cycle machine. You really need a good strong duty cycle to do that I would recomend at least 60%
Bill 52 8n
05-06-2003 15:14:45
You can buy special gouging rods that can used to cut. Crank the amps and the rod will blow the metal away. Personally, it depends what i am welding as to what i prefer. If you are going to be welding a lot of dirty or less than perfectly clean metal i would go with stick. If you have smaller projects (under 1/4") then mig is a good choice. By the way, you can cut with mig too. Turn the wire speed all the way up and the volts about 3/4, it can give a rather accurate cut.
Bill
jokers
05-06-2003 11:42:02
Try 6010 or 6011 on AC with the amps cranked up and a long arc. You can sever metal like this and it`s pretty good for piercing. Surely not pretty like a well done flame cut though. Russ
Polish Mike
05-06-2003 09:44:28
Yes, you can cut with a stick welder. There are a couple kinds of electrodes made specifically for cutting. Ask at any welder supply store.
SHeiserman
05-06-2003 03:12:29
As far as preference goes, I think it all depends on what you're used to. I'll take stick welding over any other method, any day.
MPK
05-05-2003 20:36:20
Yes, you can cut with a stick welder. Just turn up the heat and use the rod with a sort of a sawing motion with the rod pointing at the metal and sort of pushing the molten metal away.
