Renting a stump grinder
advice please!
Fritz Campbell
05-04-2003 17:38:37
I've got six pine stumps I would like to grind down below ground level. I have cut them off as close as I dare (dad's saw). I have never used a stump grinder before - any pointers? The stumps are maybe 16" or less in diameter and don't have too many exposed roots. The rental place said it should'nt take too awful long to grind them - just to make sure the big stones were away from the stump. As always, I appreciate the advice.
DumOleBob
05-05-2003 08:42:00
 Re: Renting a stump grinder - advice please! in reply to Fritz Campbell, 05-04-2003 17:38:37
I've used a big grinder on over a couple of thousand stumps. Here's the truth...
First, check with a pro stump/tree removal outfit to see how much they'd charge you. They should be able to give you an idea of cost over the phone. Then subtract the entire rental cost, including wear & tear to see if it's worth it.
Check with the rental company as to how much replacement teeth cost. In most cases you'll be responsible for wear &/or broken teeth which may cost $6 to $12 - EACH! If you hit a rock, nail, etc. you'll take out more than one - maybe all of them. If you have any rocks at all - you will find them. Tree stumps like to grow around rocks rather than just pushing them aside. Ask the Rental outfit how much they typically collect for wear & tear from other renters. I've hit rocks that cost me $300.00 & I buy teeth in bluk.
Stump grinders at least the kind you'd want to use are very powerful, very dangerous tools. They are far removed from renting lawn mowers, sprayers & drills. They can & will throw stuff a mile. Wear eye, ear, face & protective clothing. Put the kids & pets in the basement. Warn the neighbors.
Frankly, I think it should be against the law to rent them to us weekend warriors.
Bottom line - Get 'em out some other way or you go fishing while someone else grinds 'em up for $. Sorry, but that's what I'd do.
G Taylor
05-05-2003 07:45:44
Can you do the old burn barrel trick at your location? Renting a backhoe is better than ruined joints, deafness and flying chips running a stump grinder too. Plus having a backhoe around allows trenching in water or power to the far corner of your estate.
MarkB
05-05-2003 03:29:06
You shouldn't have any problem grinding out those pine stumps. Assuming, that is, that these aren't yellow pines that have been cut down long enough to turn to lighter wood! (You won't run into this if you live up north.)
The main thing is to take your time. The rental shop should show you how to run the machine. You need to attack the stump from the side, not the top, so the grinder doesn't pull itself across the stump. Take a couple of inches at a time. You'll have to keep the chips cleared away from the grinder's tires. When you think you're done, clear away all the chips; you'll find you have more work to do. Figure about thirty minutes per stump.
George
05-05-2003 00:28:24
Which version do you plan on renting -- the walk-behind version or the big one you have to pull behind a truck? If you have the time, don't mind having your arms vibrated off and have sharp cutter teeth (which rental machines seldom have), you might go with the walk-behind version. If you have truck access, the bigger tow-behind machine would be better. Or for a third alternative, contact a local tree surgeon and have him bring his professional machine out -- not that much more expensive (especially if you have several stumps to do at one time), don't have to drive back and forth to the rental place and if he breaks it, it's his!
Fritz
05-05-2003 02:58:52
 Re: Re: Renting a stump grinder - advice please! in reply to George, 05-05-2003 00:28:24
I was planning on the walk behind version. I have the time - so I guess I'll try it out. I once called a fellow who advertised tree cutting and stump grinding to quote grinding a 24" pine stump that was already cut close and I had dug away all the dirt and stones from around it. He wanted $100 for the grinding. I can rent a walk behind stump grinder from 3:00 pm Friday afternoon to 8:00 am Saturday morning for $55.
Fritz Campbell
05-05-2003 18:10:31
 Re: Re: Re: Renting a stump grinder - advice please! in reply to Fritz, 05-05-2003 02:58:52
Thanks all for the advice. The rental company told me $6 for each tooth broken off or nicked up bad enough to need replaced. I have already dug around them to remove the rocks and dirt - and then hauled the hose down and pressure washed the whole way around each one - that works pretty good. I only need to get them down below grade.
I'm glad I don't do it for a living and I'll wear my earplugs and keep the dog in the house. I don't have to worry about the kids because they scatter pretty quick when there is work being done.
George
05-05-2003 19:32:14
 Re: Re: Re: Re: Renting a stump grinder - advice please! in reply to Fritz Campbell, 05-05-2003 18:10:31
Would like to hear how it turned out and would you do it the same way the next time?
Fritz Campbell
05-06-2003 17:44:23
 Re: Re: Re: Re: Re: Renting a stump grinder - advice please! in reply to George, 05-05-2003 19:32:14
George - I'll be glad to post back and tell the story. I may not get around to them for a couple weeks though. Thanks again to everyone for their advice.
