Band saw
ken in la
05-03-2003 19:11:08
i am thinking of buying a portable band saw. I have a Huskey gas ax and chop saws.I i need to make more precise cuts. I looked at a milwakie(spelling)it was a two speed do i need that.Any input would be appreciated thanks
James In MO
05-06-2003 16:22:25
 Re: band saw in reply to ken in la, 05-03-2003 19:11:08
I have a Milwalkee deep cut variable speed band saw I bought at Home Depot for 3 and a half I htink and I love it it takes some getting used to to cut straight but it is so much better than my chopsaw it will however opnly cut straight (or a close derivative0 it will not cut 45 degree angles which I was disapointed about but for cutting pipe and round stock it is the best
Central Minnesota
05-04-2003 15:33:05
I've worn out several as a contractor. One Milw. two Black and Decker. The last one I bought is a gear drive Porter Cable. It's the best one yet. I recommend staying away from the chain drive units. Use a stick lubricant on your blade for fast cutting and long blade life.
SHeiserman
05-04-2003 13:49:47
I bought a Milwaukee deep cut bandsaw a few years back. I use it alot, and it works well. If I cut anything of size, I need to mark it really well as it is all over the place. I wish I had a chopsaw for a lot of layout work, save the bandsaw for what the chopsaw can't do.
