Air valve
cole in mo
05-03-2003 02:20:56
a few years ago I made a portable air compressor out of a 3hp engine run with another 3 hp. I replaced the spark plug with this valve that I found in some box of junk. It worked great till last week when a piece of pipe fell over and broke it. This valve was used in older times, you removed the spark plug, skrewed this valve connected to a hose into the plug hole, started the engine and inflated the tire. Does anybody know where I could find a replacement, or somthing that would work in its place? thanks for any info.
JoeK
05-03-2003 18:13:24
 Re: air valve in reply to cole in mo, 05-03-2003 02:20:56
Spark Plug pumps are still made.They do not pump cylinder air thru the hose,but use the pulse to fill the hose with fresh air taken in thru the slots on the device and push it thru the hoseCheck auto parts,farm supply stores. Also popular tool with touring motorcyclists so larger bike shops may stock also.
mj
05-03-2003 08:08:19
In the '60s & 70s all the off-road shops used to sell a kit with a sparkplug valve pump, hose and chuck to carry in your rig. I think JC Whitney used to have 'em as well. :-)
Rod (NH)
05-03-2003 04:10:09
Hi Cole,
The "valve" you are talking about looked like this, didn't it?
third party image
Check out this thread on this forum last year. There are quite a few posts there about such a valve along with a couple of possible sources. I have not noticed a source in recent years. The one I have dates back to the '50s :o). There are also a couple of suggestions in that same thread on how to cobble together such a device.
third party image Rod
cole in mo
05-03-2003 23:57:10
 Re: Re: air valve in reply to Rod (NH), 05-03-2003 04:10:09
yep thats the animal I was looking for, simple critter, but does the job. checked on what ya posted, and found some places that have them, got one ordered. Thanks to everbody for taking the time to check on this and reply.
Alan Y.
05-03-2003 04:01:31
You might be able to use an engine compression tester hose or cylinder leakdown tester hose. One end threads into the spark plug hole and the other has a quick disconnect air hose fitting.
wvbill
05-03-2003 04:01:12
they use to be commonplace,lots of folks had them,jc whitney had them in catalog till about 10 years ago,i haven't noticed them lately. should be able to have the local handyman fabricate you one pretty easily.
jake
05-03-2003 08:30:35
 Re: Re: air valve in reply to wvbill, 05-03-2003 04:01:12
Cole what you need is an air check valve which has one way flow through it. The surplus center has several sizes available. Click on air on the upper left corner.
