Help with small engine replacement
Craig Huff
05-02-2003 19:01:53
I have a Troy bilt tiller with a dead kolhler 7hp engine that I am replacing with a kohler 8hp magnum engine. I have taken 4 bottom mounting bolts out but I am at a loss as how to get the engine free. Would anyone know my next step? Could anyone tell me? I am new to engine replacement mechanics but enjoy this type of challenge. Thanks for any info, Craig Huff
chris
05-03-2003 04:57:02
 Re: Help with small engine replacement in reply to Craig Huff, 05-02-2003 19:01:53
The only bottom bolts I'm thinking of are the bottom casting of the engine. You need to remove the drive pulley from the engine and remove the four bolts from behind the pulley, or are these the bolts you're talking about?? It's best to remove the drive belt then engage the fwd/rev lever to fwd to raise the engine to allow clearance for the drive pulley. Or remove the vertical shafts that the engine slides on, remove the 5/16 bolts and slide the shafts up or down. Also the paint might be holding the engine to the mount.
