Van Dorn Valve Refacer
Don
05-02-2003 16:29:14
Anyone know anything more about this machine? Manufactured by the Van Dorn Electric Tool Company, Cleveland, Ohio. This one is a Code VR500, 1/2-inch capacity, for grinding valves from gasoline engines. In a gentleman's basement: he inherited it; I may get it.
Evelyn
09-09-2003 18:30:38
 Re: Van Dorn Valve Refacer in reply to Don, 05-02-2003 16:29:14
Does anyone know how to obtain parts for the Van Dorn Valve Refacer? I specifically need a 9/16" capacity, style NWB serial number 787239.
Jerry B
05-05-2003 07:27:17
As Dan said it is worth having. The old gentleman most likely has the seat grinder also. A valve grinder without the seat grinder kit is only half the setup.
You will also need to get valve guide reconditioning tools. These will include knurls for decreasing the ID of the guide and then reamers for returning the guide the the correct diameter.
Do not try to grind vale seats without reconditioning the guide first. The guide is what centers the grinding pilot for seat grinding. An over sized/worn/tapered guide will not center the pilot and thus the stone on the original seat and you will end up grinding away too much seat material ending up with egg-shaped seats, wide seats, and/or soft seats. None of which are good.
You might even invest in some tooling for installing guide liners. I have the tools to do 5/16"-8mm, 11/32", and 3/8". They will handle 99% of the valve guides you will encounter.
Don
05-05-2003 17:02:01
 Re: Re: Van Dorn Valve Refacer in reply to Jerry B, 05-05-2003 07:27:17
I looked the Refacer over last night. An old machine, but definitely useable. I asked about the valve seat grinder, and he said he'd look around for it. He remembers it, and thinks it probably is a different make, acquired at a different time. The tools actually were his son's, and the daughter-in-law has okayed getting rid of them. I used similar tools a few times when I was less than half the age I am now... Thanks for the tip about the guide tools. The engines I would be working on have replaceable guides, but it's something to keep in mind.
Dan in Ore
05-03-2003 06:57:25
Definitely worth having. If you have or can find a valve seat resurfacer, then you can do your own head work.
You will need to practice on something that won't matter if you make some mistakes or not.
Once you learn to use this equipment, you can save lots of money and maybe put a few schillings in your pocket.
Nice find.
Dan
