Ford D801
Gary
05-01-2003 10:29:35
Having difficulty with the 3-point lift not working. Have replaced the hydraulic oil with no effect. Replaced the O-rings several years ago and watched the Ford mechanic bench adjust the cylinder with air. Are there any adjustments that can be made to the cylinder in place to determine if that is the problem with the lift?
Al
05-03-2003 21:45:17
 Re: Ford D801 in reply to Gary, 05-01-2003 10:29:35
Gary,could be your pump.At the rear top of pump there should be a plug,remove it and turn the engine over with the starter,remove the coil wire so it won't start,see if you get any oil pumping out,watch it cause you can get a bath.If you get oil then it's probably in the lift cyclinder.
Gary
05-07-2003 17:55:41
 Re: Re: Ford D801 in reply to Al, 05-03-2003 21:45:17
Thanks. I had already gone through the bleeding procedure and have pretty much concluded, like you, that the cylinder probably needed some attention. I was hoping not to have to take it out to give it that attention.
