What size air impact wrench is good for working on tractors?
Al Thigpen
09-03-1998 12:52:34
I'm thinking about buying an impact wrench to take an Allis-Chalmers Model G tractor apart with. I have a much bigger tractor also. What size impact wrench would handle the job and loosen lug nuts also? Thanks, Al.
Paul
09-04-1998 07:31:14
 Re: What size air impact wrench is good for working on tractors? in reply to Al Thigpen, 09-03-1998 12:52:34
My 2 cents
I use a 1/2 inch IR, which works out great, get the most powerful one your compressor will handle, both cfm and psi. I use Snap-on regular 6pt sockets, and found no need to buy inpact sockets, Be warrend not all sockets are of the Snap-on quality. good luck let us know what you buy
Paul
Ewell Tucker(Tucker Tire)
10-04-1998 15:19:44
 Re: Re: What size air impact wrench is good for working on tractors? in reply to Paul, 09-04-1998 07:31:14
: My 2 cents
: I use a 1/2 inch IR, which works out great, get the most powerful one your compressor will handle, both cfm and psi. I use Snap-on regular 6pt sockets, and found no need to buy inpact sockets, Be warrend not all sockets are of the Snap-on quality. good luck let us know what you buy
: Paul
I/2 inch Snapon is the most powerful gun I have found in tire work. next best is Ingersol Rand Ben using these wrenches in tire work for 30 yr. Be sure and use oil in line occasionally I use Marvel Mystery oil works wonders on power of wrench. HOpe this helps Ewell Tucker 800 443 0802
DaBrow
09-03-1998 18:26:45
: I'm thinking about buying an impact wrench to take an Allis-Chalmers Model G tractor apart with. I have a much bigger tractor also. What size impact wrench would handle the job and loosen lug nuts also? Thanks, Al.
I use a 1/2"CP unit on my 8N & MF-35. Only on the lower settings for 1/2" & 9/16" nuts. My compressor is set at 120 lbs.My backup rig is a 3/4" power bar and 4" of pipe.
matt shaffer
07-14-1999 18:42:32
 Re: Re: What size air impact wrench is good for working on tractors? in reply to DaBrow, 09-03-1998 18:26:45
: 1/2" for most stuff 3/4 for serious stuff : 160psi dont worry
Wild Bill
09-03-1998 19:43:21
: : I'm thinking about buying an impact wrench to take an Allis-Chalmers Model G tractor apart with. I have a much bigger tractor also. What size impact wrench would handle the job and loosen lug nuts also? Thanks, Al.
: I use a 1/2"CP unit on my 8N & MF-35. Only on the lower settings for 1/2" & 9/16" nuts. My compressor is set at 120 lbs.My backup rig is a 3/4" power bar and 4" of pipe.
Yes, a 1/2" drive should handle most of it. I have always had good luck with Ingersoll impacts.
Al Thigpen
09-04-1998 11:55:34
 Re: Re: Re: What size air impact wrench is good for working on tractors? in reply to Wild Bill, 09-03-1998 19:43:21
: : : I'm thinking about buying an impact wrench to take an Allis-Chalmers Model G tractor apart with. I have a much bigger tractor also. What size impact wrench would handle the job and loosen lug nuts also? Thanks, Al.
: : I use a 1/2"CP unit on my 8N & MF-35. Only on the lower settings for 1/2" & 9/16" nuts. My compressor is set at 120 lbs.My backup rig is a 3/4" power bar and 4" of pipe.
: Yes, a 1/2" drive should handle most of it. I have always had good luck with Ingersoll impacts.
Thanks for your help. Al
Slow Poke
09-04-1998 21:38:16
 Re: Re: Re: Re: What size air impact wrench is good for working on tractors? in reply to Al Thigpen, 09-04-1998 11:55:34
: : : : : I'm thinking about buying an impact wrench to take an Allis-Chalmers Model G tractor apart with. I have a much bigger tractor also. What size impact wrench would handle the job and loosen lug nuts also? Thanks, Al.
: : : I use a 1/2"CP unit on my 8N & MF-35. Only on the lower settings for 1/2" & 9/16" nuts. My compressor is set at 120 lbs.My backup rig is a 3/4" power bar and 4" of pipe.
: : Yes, a 1/2" drive should handle most of it. I have always had good luck with Ingersoll impacts.
: Thanks for your help. Al
Suggest an Ingersoll Rand IR-2131. It is a little more expensive but also has more power using the same psi and cfm.
