Jim
04-28-2003 05:32:53
Re: chainsaw selection(brand, size, bar length, etc.)??? in reply to Johnny, 04-27-2003 19:10:33
Just my two cents worth. I have been in this businesss for 25+ years and have seen a lot of saws. As for a Stihl, if you buy the even number saws, you are getting a pretty decent saw, odd number saws are the cheaper version of Stihl saws. the only advantage is that Stihl has dealers all over the place,but,they have to know what they are doing to do you any good. RedMax makes a great little saw for about $230.00. 38cc, 16" bar, dealers are not real plentiful, they are like Lexus dealers, few and far between, but have a good product. Echo makes a good saw also. Basically, what I am saying is, there are a lot of saws that are real good, but a chain saw is a very specialized peice of equipment, and you need to buy one from someone that will give you good service, because a saw, no matter how well it is built is not worth 10 cents if the person you buy it from is not qualified or capable to work on it. Then you Husquvarna, Sachs-Dolmar, Johnsred, Poulan Pro, Shindiawa. Do not buy a green Poulan/Craftsman, most all green Poulans/Craftsman, are not vibro insulated, and after you run one of them, you will regret the fact that you have no iso-mounts. The reason you want something with iso-mounts is to reduce the vibration because most of these saws top out at about 13,000 RPM, so that is a lot of vibration and when you get done it will feel like you have a hand full of bumble bees. So, with this said, I hope you make this decision carefully, if you have any other questions, email me and I can just about tell you the good and bad of any saw made. As for bar size, stick with a 14" or 16" bar, they are small, well balanced, and can cut a 28-32" tree, but are small enough for the 6-8" trees you always run into. 38-45cc is a good size, again, light weight, but powerful enough for most cutting.
