Ryobi Weedeater
Andy in FL.
04-27-2003 08:04:09
I bought a used Ryobi model 775R 31cc 16" weedeater. It runs great but I'm not sure if I put the string in right. The reel has 2 slots with a "cross-over" groove to each other. There are several holes to put the end of each string in. Is there a certain way you should install? It seems to feed ok when I bump it but I thought maybe someone would have a manual on this model that they could post a picture of the instructions on loading the reel. thanks, Andy
Tom
04-28-2003 17:06:39
 Re: Ryobi Weedeater in reply to Andy in FL., 04-27-2003 08:04:09
Well, Holy Cow, I can finally help someone on this board. (Too many knowledgeable people in one place) I have a Ryobi 975R and am hoping that the instructions that I give you directly from the manual will help.
1. Line up arrow on the inner reel with the arrow on the outer spool.
2. Insert 10 feet of trimming line straight into one of the two eyelets and push it up throught the line exiting hole in the inner reel. Do not bend the line when inserting into the eyelet.
3. Insert the line into the locking hole no more than half inch. do onot push the line too far into the inner reel. A small loop is formed when the line is inserted correctly.
4. Pull the line away from the spool until the line is tight against the inner reel.
5. Repeat the procedure with the second eyelet and use the same amount of line as specified in step 2.
6. Wind the inner reel counterclockwise until approximately four inches of line remains outside of the eyelets in the outer spool.
7. If winding the line becomes difficult or the line jams, pull the ends of the line away from the spool and continue winding the inner reel counterclockwise.
rod
04-28-2003 06:06:33
look for an arrow on the head that is the way you wind the string on. regards
rod
