Attaching new floor on flatbed, what to use?
Bob G
04-25-2003 12:20:56
I am going to be replacing the old rotten wood on my one ton. I will be putting wood back in. I was going to use carriage bolts, but would like to know what else is available. Is there any self-tapping screw made that could be used for this. And if there are where could I find them.
Thanks,
Bob
fred kobs
04-27-2003 06:47:03
 Re: Attaching new floor on flatbed, what to use? in reply to Bob G, 04-25-2003 12:20:56
Screws as johnny b. describes are also available at semi-trailer dealers. they use them on dry van floors. usually sold by the lb. if I remember right they are cheaper than 15cents @ that way. also use a 7/64 bit i think. i have 2 tlrs. to redeck and that's what i plan to use
Paul K.
04-26-2003 09:47:39
Another option would be what they call elevator bolts.They have the same square neck as carriage bolts but a much larger flat head for more board contact and support.
kjm
04-25-2003 21:02:12
What farmered said,drill and screw at the same time,they work great
JohnnyB
04-25-2003 14:15:26
I use a 1/4" x 2" self taping countersunk screw, has a #30 torx head, drill hole first with I believe a 9/64" bit, could be wrong on the correct bit size, 3/16" will work too. All our local hardware stores sell em , 15 cents a screw. My last semi trailer floor(40 ft.) required 300 screws. They sell the self taping screws also, but I prefer to drill the hole.
Farmered
04-25-2003 12:37:25
Bob, There are self drilling and tapping screws available. Call Fastenall. They have outlets in the larger towns. Ed
Glenn(WV)
04-27-2003 13:06:26
 Re: Re: Attaching new floor on flatbed, what to use? in reply to Farmered, 04-25-2003 12:37:25
I wish the Fastenal outlet here would sell to the public. If you don't have a West Virginia contractor's license, they will not sell to you; they've even posted a sign on the front door to that effect. While I can understand their policy, it does make things difficult if you need an oddball piece of hardware really quick. :-(
Ray,IN
04-25-2003 20:24:25
I use 5/16" carriage bolts. Harder to install, but will outlast the wood. I've seen many self-tapping screws rust so much the threads let go and the board flopps around. I 've never had problems with carriage bolts.
