Fpm for sawing steel
john
04-23-2003 06:34:07
What is a good fpm speed to saw 1/4 and 3/8 steel plate? Thanks
Rod (NH)
04-23-2003 19:03:27
 Re: fpm for sawing steel in reply to john, 04-23-2003 06:34:07
Hi John,
I am assuming you are talking about a bandsaw. An old Delta bandsaw book that I have indicates 175 sfpm for plain old carbon steel up to 1" thick. Of course you would need a metal cutting blade. The teeth/in is recommended as 14 for 1/4" to 1" thick stock.
third party image Rod
hjp
04-23-2003 18:42:55
saw ??I mean there is a lot of variables !!!
teeth per /inch ie. 18/24/32
horse power of the cutting unit
type of blade material
I would use a oxy setup or a plasma cutter
